Please help!! Remove key wait ten seconds
Old Nov 9, 2020 | 06:06 PM
Zeke Freudiger's Avatar
Zeke Freudiger
6th Gear
Default Please help!! Remove key wait ten seconds
So I have the message to remove key wait ten seconds. Battery was dead took it to have it charged and tested, Tested good. Can’t pull any codes because message won’t go away. No issues before. No security light, but does shut off when trying to drive. No steering lock message. And checked bcm looks good no corrosion. Any ideas or tips will be greatly appreciated!
Popular Reply
Nov 9, 2020, 06:22 PM
wdcraig's Avatar
wdcraig
LMC5 module from Compliance Parts is the answer. It worked for me and I believe it to be the most effective solution. Takes a bit of DIY- but if I can do it, almost anyone can!
http://complianceparts.com/lmc5ataglance.html
Old Nov 9, 2020 | 06:17 PM
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
One of the most common C5 issues. Dealt with this 1 week after I got mine. Good news is there is a TON of info by folks that have already gone thru this. I would start by doing and advance search for "Column Lock" and you are sure to find what you are looking for.
Here is one to start with. https://www.corvetteforum.com/forums...ky-please.html
Old Nov 9, 2020 | 06:22 PM
wdcraig's Avatar
wdcraig
Old Nov 9, 2020 | 11:48 PM
Moved to C5 Tech.
Old Nov 10, 2020 | 09:01 AM
slapshot12's Avatar
slapshot12
Veteran: Coast Guard
Another vote for the LCM5. It got rid of my service column lock message. The install isn't too bad, just follow the directions step by step.
Old Nov 10, 2020 | 09:08 AM
bjones7131's Avatar
bjones7131
Is column locked or just the message? When GM did the recall and assume your car had it done yrs ago they programmed in a 2 MPH fuel shutoff is reason it is shutting off. 2 MPH shutoff was to cover there behind in case the recall didn't work. LMC5 is your best avenue for resolution. Around 40-50 bucks. Good luck with it.
Old Nov 12, 2020 | 07:55 PM
Zeke Freudiger
6th Gear
Default **Update **
no column lock message just the pull key and the shut off after 2mph. Lmc5 is ordered be here next week. Today out of boredom I tried to start the car to find a battery under 10v not allowing car to start. When parked a few days ago battery was freshly charged and tested from local auto parts store. I did disconnect neg battery terminal the other day before calling it a night. Do y’all think bad battery causing issues as well? Or can u get a parasitic drain with neg unhooked?
Old Nov 12, 2020 | 08:04 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Low battery voltage can cause MANY C5 issues...with negative battery cable disconnected you will not drain the battery if you do a have a drain but you need to address that first !!...don’t know your skills but there are many YouTube videos on how to do a parasitic drain test.
Old Nov 12, 2020 | 08:06 PM
bjones7131's Avatar
bjones7131
Bad battery definitely causes problems on C5 for sure. I wouldn't think you would get a draw with negative unhooked but not an electrical guru. My guess is bad battery, how old is it? Good luck with it.
Old Nov 12, 2020 | 08:22 PM
Zeke Freudiger
6th Gear
Default Thanks for the help
I’m actually an electrician so I do know my way around circuitry and a meter however... Not really complicated dc circuits but with you tube I should be able to figure it out lol. I’m having a hard time believing battery is good, even though oreilys is saying its testing good. Thanks for all the help I’ll be sure to post what I find
Old Nov 12, 2020 | 08:42 PM
C5 Diag's Avatar
C5 Diag
If you do perform a parasitic drain test don’t do the “pulling fuses” procedure but “voltage drop” instead...you’re an electrician so shouldn’t have to walk you through it !!
Old Nov 13, 2020 | 12:19 PM
mmartinez's Avatar
mmartinez
Make sure your battery is good have it charged and load tested again at a different auto parts store, and no there is no way a battery can be drained with negative battery cable disconnected.
Old Nov 13, 2020 | 04:11 PM
bc6152's Avatar
bc6152
Here's how to install the LMC5 ...
To Please help!! Remove key wait ten seconds
