Keep getting a "Pull key, Wait 10 seconds" message.
Old Dec 5, 2002 | 12:46 PM
Tonycino's Avatar
Tonycino
From: Littleton "Nitro must be the magic elixir in the Fountain of Youth"
Default Keep getting a "Pull key, Wait 10 seconds" message.
Just wanted to find out if this is usually caused by something. It happens on a '97 6-speed car. Everytime I get into the car it says this. I do as it says and it runs fine afterwards. Any help would be appreciated.
Thanks,
Tony
[Modified by Tonycino, 5:46 PM 12/5/2002]
Old Dec 5, 2002 | 02:26 PM
intel55's Avatar
intel55
Default Re: Keep getting a "Pull key, Wait 10 seconds" message. (Tonycino)
I got that sometimes after I installed the CLB. I think I had to clear the code or disconnect the batt. and then it never appeared again. :cheers:
Old Dec 5, 2002 | 03:02 PM
jerryv's Avatar
jerryv
That's the message that C5ers get shortly before the steering column refuses to unlock .. more or less permanently. Normally followed by a flatbed trip to the dealer for repair. If you've already installed a column lock bypass you should be ok ... if not, it may be time to do so.
Old Dec 5, 2002 | 03:07 PM
Untouchable00's Avatar
Untouchable00
That meesage gives me the chills just thinking of it. I got stuck very far away from home because of it... :nono:
Old Dec 5, 2002 | 03:26 PM
Tonycino's Avatar
Tonycino
Default Re: Keep getting a "Pull key, Wait 10 seconds" message. (Jerry Velders)
Thanks guys, I'll check with our service writer on that and hopefully it is a non issue.
Old Dec 5, 2002 | 03:45 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I believe this message is caused by the car not "reading" the key resistor correctly. Try cleaning the resistor pellet on the key, or try the other key and see if that helps.
:cheers:
Old Dec 5, 2002 | 03:53 PM
wwashing's Avatar
wwashing
Default Re: Keep getting a "Pull key, Wait 10 seconds" message. (Y2Kvert4me)
:cheers:
Also try cleaning the contacts (a little alchohol) in the key slot.
This message does not necessarily mean you have a problem with column lock. The "Service Column Lock" message is the more disturbing one. :iagree:
Old Dec 5, 2002 | 04:37 PM
spdnman's Avatar
spdnman
This happened to me for about one month before the steering column locked, then I got caught far from home in a small parking garage. It was a real pain. I'd have your car serviced NOW, rather than later.
Old Dec 7, 2002 | 01:02 AM
AZCARGASM's Avatar
AZCARGASM
I recommend listening to the C5 owners who had this happen to them. Tow truck are our enemy! Column lock can ruin two or three days if your stuck in Podunckville Do you really want someone at the 'fillin station' messing with your C5? :reddevil :reddevil
Old Dec 7, 2002 | 10:18 AM
chocoholic's Avatar
chocoholic
Before you get sucked off into flaming icon land, consider that your problem might be as simple as just needing to clean the resistor pellet in the key.
Old Dec 7, 2002 | 10:34 AM
batsallover's Avatar
batsallover
Default Re: Keep getting a "Pull key, Wait 10 seconds" message. (chocoholic)
:yesnod:
Worked for me. I had the same message back in May or June. Aftercleaning the key, I have never had the problem since. :cheers:
Old Dec 7, 2002 | 12:15 PM
rrobert22's Avatar
rrobert22
I knew by the title of this post you must be new to the forum :lol: Sorry, but this problem is so prevalent around here you wouldnt believe it. Column lock :cheers:
To Keep getting a "Pull key, Wait 10 seconds" message.
