Abs issue 2000, c5 corvette no codes
Old Dec 18, 2020 | 08:01 PM
thevelvetglove's Avatar
thevelvetglove
Default Abs issue 2000, c5 corvette no codes
MY ABS IS NOT THROWING ANY CODES.
WHEN I HIT THE BREAKS HARD, THE PEDAL JUST LETS OFF A SMALL VIBRATION BUT DOES NOT PUSH BACK LIKE WHEN THE CAR WAS NEW. aS I SAID, NO DIC CODES SO WHAT IS HAPPENING- THANKS
Old Dec 19, 2020 | 10:14 AM
grinder11's Avatar
grinder11
If no codes, and pedal still vibrates/pushes back, I would have no concern with it. Different surfaces and situations probably result in different brake pedal pressure by the driver, hence the different pedal response. For instance, if your txting while on the freeway in the rain, and you look up only to see cars stopped 100 feet away, you may be inclined to mash the pedal, HARD! If you hit a patch of gravel while trying to stop for a red light, on a dry surface, the pedal effort would probably be considerably different, as are the 2 surfaces and conditions. Just saying. BTW, does your DIC flash "ABS active", and/or the skidding yellow Corvette on the IPC light up? With no codes, I would think you're OK.......
Old Dec 20, 2020 | 11:45 PM
thevelvetglove
Yes it shows abs light. So in light of your comment, I stepped hard on the gas pedal on a wet road and still only got a slight vibration, and almost lost control of the car as the abs did not seem to work as designed. That is the best I can explaine it. Thx
Old Jan 11, 2021 | 08:28 PM
thevelvetglove
Thanks Grinder11: I am still evaluating this issue and will get back to you. thanks
Old Jan 12, 2021 | 08:50 AM
grinder11's Avatar
grinder11
I hope your ABS issue is fixable. I have been told it's a good idea to take the car out once in awhile in the rain, or while the streets are still wet and somewhat slippery, to exercise the EBCM. I also own a 2000 Vert, and we 1997-2000 owners didn't get dealt the best hand when it comes to EBCM and the SWPS!!! Good luck....
Old Jan 12, 2021 | 11:26 AM
helga203's Avatar
helga203
Did you check the fuses?
Old Jan 17, 2021 | 12:48 AM
thevelvetglove
Sorry I dropped offline. I did not check the fuses yet. Are they in the footwell or in the engine compartment?
Mahalo
Old Jan 17, 2021 | 09:39 AM
helga203's Avatar
helga203
Mahalo
Under hood pass side. Its the 20 and 40 amp . 52 and 53
To Abs issue 2000, c5 corvette no codes
