Need real answer: Does removing the cat's increase power?
Old Dec 11, 2002 | 09:39 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: Need real answer: Does removing the cat's increase power? (Mike Mercury)
I know of a few people (non vettes) who pass the sniffer with no cats. That is, the emissions from the tailpipe are still within the llimits for that car. (here at least). I find it difficult to believe those cars pollute the equivalent of 100 cars each. :rolleyes:
Whats even better, is most places seem to be migrating to testing OBDII cars by simply tapping into the computer. If it's not throwing codes, it's good to go. Drop the cats and put 02 sims on, no problem. The people with visual inspection would likely have a problem though.
I have the 02 sims on my car already, with the cats. I could easily drop the cats if I wanted, install the ORP's, and still probably pass emissions with flying colors, or just swap the cats back in before testing. Don't really see a need to though, that minor increase in power isn't worth the hassle or federal law infraction to me. I don't really need nor want it any louder either. :D
:cheers:
Old Dec 11, 2002 | 09:45 PM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: Need real answer: Does removing the cat's increase power? (Aquaman)
I do not recommend anyone pulling their cats, especially on stock cubes n/a, but I love how everyone says, "It only gave me 5rwhp...", and never mention the fact that the car was not tuned to take advantage of removed cats.
Yes, the sound is awesome and I am running B&B Triflow Rt. 66 mufflers! Of course cubes and a good cam really contribute to that. :crazy:
[Modified by C5-VERT, 12:51 PM 12/12/2002]
Old Dec 12, 2002 | 08:42 AM
Rx7Rob's Avatar
Rx7Rob
Default Re: Need real answer: Does removing the cat's increase power? (Tom Steele)
AMEN BROTHER!!
I certainly didn't vote for the change that reduces emissions requirements for the nations dirtiest power plants!
You want to clean up the air, plant a tree and get on your congressperson to start making POWER COMPANIES and INDUSTRY stop polluting so much.
I - to this day - still don't know how WE, the people, got saddled with the burden of cleaning the air by having our cars so squeaky clean while big business seems to have gotten off scot-free.
Old Dec 12, 2002 | 11:59 AM
BigBlue's Avatar
BigBlue
Default Re: Need real answer: Does removing the cat's increase power? (larrysb)
With all due respect Tom, you are FOS.
Even diesels have cats today.
You are wrong my friend. Diesels do not come with cats. They come with something called a resonator. It is a 30% cat. A diesel doesn't really get hot enough to activate them. Diesels are also emissions exempt. I have straight pipe on mine and just got it inspected without any troubles. A diesel actually puts out less harmful particles than a gasser. A semi puts out as much harmful pollution (the stuff you can't see) as a minivan. It puts out more particulates (the black smoke). That's off boost though. You tip into boost and that exhaust cleans up real quick. My smokes like a freight train off the line but by 20mph, I'm half spool (15psi) and my exhaust is crystal clear. Just thought I would let you know.
Old Dec 12, 2002 | 12:14 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Default Re: Need real answer: Does removing the cat's increase power? (BigBlue)
Unless you increase your displacement, removal of the cats will not help you significantly.
Old Dec 12, 2002 | 01:35 PM
Tom Steele's Avatar
Tom Steele
Default Re: Need real answer: Does removing the cat's increase power? (KingTut)
Everytime you post you use up large portions of the page quoting other people and directly confronting their opinions.
Get a bigger monitor then. I use large portions of the page because I actually RESEARCH the stuff I am talking about and quote sources rather than just spouting off my unsupported opinions. I know its a novel idea, and perhaps confusing to those who are used to the simplified version of things - but it is actually the correct way to debate an issue.
I am not sure of any of your actual positions on things,
Which part is hard to understand? I think that removing the cats will gain you a few hp and I don't have a problem with it.
only that you find excessive faults in others opinions.
So are you saying that this forum should be like this:
1st person: Here's what I think...
2nd person: Me too!
3rd person: I agree too!
ad nauseum...
So in a purely defensive positioning I am not stating any opinions on this topic. :blueangel:
How convenient. I am willing to put my opinions out there to be agreed with, or challenged.
Old Dec 12, 2002 | 02:07 PM
KingTut's Avatar
KingTut
Your reply is self incriminating. :seeya
Old Dec 12, 2002 | 04:24 PM
TLewis4095's Avatar
TLewis4095
Tom, I have to stick up for you...your right on, although I don't encourage anyone to remove their cats...it should be their choice.
And on the diesels, they put out visible smoke, but these are mostly less harmful large particles that fall to the ground more quickly, not suspending in the air. And yes, the exhaust temp is not high enough to heat a traditional cat hot enough to be effective. I drive a Excursion diesel for the race car tow vehicle. :cheers:
Old Dec 12, 2002 | 04:36 PM
scool93535's Avatar
scool93535
Keep up the good work Tom, I need an excuse to get one of those wheeled mice to scroll the screen. :D
Just my way of saying I appreciate the extra effort to support your point of view.
:cheers:
Old Dec 12, 2002 | 04:48 PM
jimman's Avatar
jimman
Default Re: Need real answer: Does removing the cat's increase power? (QUIKAG)
You would think you would get more hp. Haven't seen it with observing over a dozen dyno tests. Some loose some gain a couple all within the dyno error range so don't waste your money and time on it. For those you see 10, your breathing the fums guys.
Old Dec 12, 2002 | 05:28 PM
UtahVince's Avatar
UtahVince
Default Re: Need real answer: Does removing the cat's increase power? (jimman)
What about weight savings?
Old Dec 12, 2002 | 05:31 PM
97C5ENVY's Avatar
97C5ENVY
For peak it did nothing for me, however at 3500 rpms i lost about 5 lbs TQ. I can even post a comparison dyno graph if you like....JLMK.
Old Dec 12, 2002 | 05:37 PM
  #33
Mordenkanen's Avatar
Mordenkanen
I dont think i will remove mine :nonod: :chevy
Old Dec 12, 2002 | 05:38 PM
  #34
SoCal C5's Avatar
SoCal C5
Default Re: Need real answer: Does removing the cat's increase power? (UtahVince)
I witnessed one forum member gain 6rwhp by removing the cats and adding O2 sims. His car had long tubes, cold air, maf translator, maf ends, and maybe a few more bolt-on type mods, but no head work, cam change or inclreased displacement.
Old Dec 12, 2002 | 05:39 PM
  #35
KerryH's Avatar
KerryH
Keep it up Tom, I agree with you most people don't research but just reply what someone else may have heard. You know, I haven't seen any of the big tuners who post on every other issue jumping in here with they're actuall dyno results to help justify the HP gains.
Old Dec 12, 2002 | 06:03 PM
  #36
QUIKAG's Avatar
QUIKAG
Default Re: Need real answer: Does removing the cat's increase power? (KerryH)
Thanks for all the info. Sorry to see my question go so far off topic. :D
KingTut, You're going into battle unarmed against Tom. Good luck!! :thumbs:
Old Dec 12, 2002 | 06:33 PM
  #37
Mike Mercury's Avatar
Mike Mercury
I'll trade my 2002 Z06 in for a 1967 Vette that pollutes a hundred times as much ...?
how much time did you spend researching that? :rolleyes:
[Modified by Mike Mercury, 6:33 PM 12/12/2002]
To Need real answer: Does removing the cat's increase power?
Old Dec 12, 2002 | 06:35 PM
  #38
larrysb's Avatar
larrysb
Wrong.
We've owned two brand diesel cars in the last two years and they both are equiped with catalysts.
Says so right on the EPA sticker. I looked in the cat for one myself. It is indeed a catalyst matrix, just like a gasser.
Diesels are exempt from testing in many states, but they are NOT emmissions exempt. In many states opacity tests of the exhausts are required. The only reason they are not subject to rigorous testing in California is there are so few passenger cars equipped with diesels and the equipment required to test them is substantially different than that required for gasoline engines. Beginning in MY 2004, diesels will be coming under the same rules as gasoline vehicles as far as pollution goes.
Diesel produce far greater amounts of NOx and particulate matter. Particulate matter includes visible smoke particles. However PM is mostly composed of particles which are not visible and diesel do produce more of those than gasoline engines do.
Old Dec 12, 2002 | 06:47 PM
  #39
larrysb's Avatar
larrysb
Tom,
You are quite incorrect about NOx and diesels.
Diesel engines produce FAR greater quanties of NOx due to the over-abundance of oxygen available in the combustion chamber and the high peak temperature and pressure due to the higher compression ratios.
Compare the rolling dyno smog tests of a car with and without catalysts. The emmissions of unburned HC are 100 times greater without. I've seen it with my own eyes.
WTF do you think the "smell" is that people are talking about after pulling the cats?
It's unburned HC!!!
Geez, we've come so far in reducing pollution AND getting performance, WHY screw it up?
1. It's illegal in every state of the union.
2. It really does create a serious amount of pollution.
3. It doesn't gain any material improvement in performance.
Leave the damn things in place, unless you wish to go back to the truly horrendous era of 1973-like smog motor performance. Be thankful we have low-pollution and performance in this day and age!
While *TRUCKS* including SUV's fall under different rules, Corvettes are *CARS* and they fall under *CAR* rules which are the same for everybody, hot-rod freak or not.
Old Dec 12, 2002 | 07:10 PM
  #40
johnnyC5's Avatar
johnnyC5
Everytime you post you use up large portions of the page quoting other people and directly confronting their opinions. I would suggest that you just clearly and concisely state your position on the subject and leave it at that.
LOLOLOL.... that is a Classic!!!!
i sometimes get too lazy to read Tom's posts.... ok, actually all of the time.... but the last time i checked, this was a Public Forum, and Tom is free to write what he chooses. Let the moderators worry about net etiquette.
sometimes you need to quote someone, because the point gets lost as the posts accumulate in the thread. if you dont like it, go to the next post, simple. gotta love how people try to tell others how to behave on forums...
im glad my mouse has that roller feature.....
im still laughing ....this place is toooo funny sometimes.
