Gas cap button quit working
Old Mar 10, 2021 | 01:07 PM
501c5vette's Avatar
501c5vette
Default Gas cap button quit working
Went fill up and the gas door release bottom doesn’t work any ideas ? Any tricks for opening from emergencies when it wot open.
Old Mar 10, 2021 | 01:29 PM
MetalMan2's Avatar
MetalMan2
https://www.corvetteforum.com/forums...post1575440270
Old Mar 10, 2021 | 01:32 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
First check the fuse. That is likely your problem. Although I've heard of locking gas caps causing this issue as well. There is an emergency release pull in your truck that will allow you to open the filler door.
Old Mar 10, 2021 | 01:42 PM
VetteMed's Avatar
VetteMed
The emergency release is a very tiny steel cable up near the left rear wheel well.
It's possible the connector came off the switch -- it's a very poorly designed connection and probably saved GM 5 cents per unit instead of a nice secure weatherpack. May need to pull the rear half of the console out to check.
Old Mar 10, 2021 | 01:51 PM
501c5vette's Avatar
501c5vette
I have a locking cap . Haven’t checked the fuse it did nothing no click nothing . Thanks off to start troubleshooting .
Old Mar 10, 2021 | 02:35 PM
grinder11's Avatar
grinder11
......."5 cents per unit"......Gotta love bean counters, who are penny smart and totally dollar stupid.......
Old Mar 10, 2021 | 02:37 PM
grinder11's Avatar
grinder11
Same beancounters who said no ROI by tumble polishing the LS7 Ti valves, I'm sure
Old Mar 11, 2021 | 09:59 AM
Moved to C5 Tech.
Old Mar 11, 2021 | 08:12 PM
Bubba1951's Avatar
Bubba1951
Can you hear a clicking sound under the gas door? If you can try pushing on the gas door as you push on the switch. Once in while I have to do that on my 1999.
Old Mar 11, 2021 | 08:25 PM
501c5vette's Avatar
501c5vette
nothing no tick still haven’t looked at it . I’m going to start from the fuse and go from there
To Gas cap button quit working
