1998 Convertible
Old Apr 27, 2021 | 03:15 PM
Texascorvett.'s Avatar
Texascorvett.
Cruising
Default 1998 Convertible
I have a 1998 convertible the windows no longer go down half inch when you pull the door handle to open the door and when you turn the ignition. That feature from my understanding helps the window locks snuggly underneath the convertible top, any advice
Old Apr 28, 2021 | 11:55 AM
C5MSG2004Vert's Avatar
C5MSG2004Vert
The C5 convertible windows do not index when you open and close the doors. Did yours ever do that?
Old Apr 28, 2021 | 12:09 PM
Texascorvett.
Cruising
Default Windows not going down
Correct, they would automatically go down about 1/2 in or so lowering down upon entrance of my vehicle, once I engaged the key the windows would go up to fit under the Convertible top, I was looking at replacing my convertible top and the installer identified that the windows no longer move down to that level, he recommended get that feature fixed before installing a new $1,500 Convertible top
Old Apr 30, 2021 | 10:45 AM
grinder11's Avatar
grinder11
For the record, I have NEVER heard of any C5 having this feature. I believe the C6 does, but not the C5. At least, I've never met anyone who had this feature. I've owned my 2000 vert for 18 years, and it never did this. My car has every available option except the Mag wheels, and engine block heater. You must have a very unusual car.......
Old Apr 30, 2021 | 10:50 AM
wmupaprmkr's Avatar
wmupaprmkr
Cool Hand Luke of W MI
My 2000 windows do not index and i wish they would. My 2014 C7 did. If I recall it is to reduce the pressure build up in the car when closing the door since the windows do not have a metal frame around them.
Old Apr 30, 2021 | 01:37 PM
Smoken1's Avatar
Smoken1
I know my 02 does not do that
Old May 1, 2021 | 11:15 PM
DWAVette's Avatar
DWAVette
My 99 does NOT do that. I intentionally leave the driver window down about 1/4 inch so it will clear the top rear of the top.
Now...my wife’s 2006 VW Beetle Vert does index the windows. Pretty nice little feature.
Old May 2, 2021 | 11:47 AM
purrvert's Avatar
purrvert
Possibly a failed Window Valet.
Old May 3, 2021 | 04:27 PM
old stingray's Avatar
old stingray
Never on mine.
Old May 4, 2021 | 01:13 PM
vetteLT193's Avatar
vetteLT193
C5's don't do that. You may have had an aftermarket alarm or window valet that allowed it. If your windows are hitting the roof there is a simple adjustment to fix that on the roof itself
Old May 4, 2021 | 01:27 PM
Texascorvett.
Cruising
Ok, thanks I just wanted to make sure before I get a new top put on, the installer mentioned that my windows should go down so they don’t mess up the corners of top. I’m still looking into first before I purchase the top. I keep getting different responses regarding the C5 windows.
Old May 4, 2021 | 03:11 PM
DWAVette's Avatar
DWAVette
Adjust the window or top?
Point me to the information please?
Old May 4, 2021 | 03:22 PM
Smoken1's Avatar
Smoken1
Here is for the top
http://www.c5forum.com/forum/ubbthre...te_id=1#import
Old May 4, 2021 | 04:51 PM
vetteLT193's Avatar
vetteLT193
Originally Posted by Smoken1
thats it. The main thing that is kinda confusing about that writeup is the 13mm nut is the one you adjust... not the one the arrow is pointing to! You need a 13mm socket with an extension, the nut is vertical if you open up the hinged flap on each side. That adjustment is really the main one that makes a difference. It takes maybe 20-30 minutes if you take your time... with most time spent putting the top up and down along with the windows
To 1998 Convertible
