2003 Battery problem
Old May 25, 2021 | 10:09 AM
BILL0798's Avatar
BILL0798
2nd Gear
Default 2003 Battery problem
2003 corvette Was there a problem with battery going dead if sitting a couple days? A mechanic said he thought it was a short and disconnected fuses for he said the steering and air bag. Still went dead after couple days.Battery is 2 yrs old. I've heard this was a common prob.
Old May 25, 2021 | 10:34 AM
Dbl_D718's Avatar
Dbl_D718
It's pretty common to have a slow drain on the battery with these cars, but the battery should last at least 2 weeks before going dead. It should really last longer, but I think of 2 weeks as kind of a minimum. If your battery sat in the car through winter without a charger or was otherwise allowed to go completely dead, it could be bad now even though it's only 2 years old. You could get the battery tested at AutoZone or just try replacing it. Otherwise you can try pulling different fuses or using a multimeter as some first steps to look for the cause of your drain.
Old May 25, 2021 | 10:55 AM
knewblewkorvette's Avatar
knewblewkorvette
https://www.batterytender.com/Battery-TenderR-Plus
Use the above or something like it. Ctek also make a great version of a battery tender.
But, your car's battery should last more than two days. The seat modules are a known culprit of not shutting off and cause the battery to drain. The Bose system is another culprit.
When you replace your battery go with an AGM style battery.
Old May 25, 2021 | 11:01 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
2 weeks is an absolute minimum. If your battery is draining in a day or two you have a problem. I agree that you should get the battery tested, if you haven't already. You'll want to make sure that you have an AGM battery. If your battery leaks, it can do MAJOR damage on a C5. A new battery, and a tender will at the very least keep your battery from dying. However, if it's still draining at a super high rate, you'll need to track down the source. Good luck.
Old May 25, 2021 | 12:11 PM
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
St. Jude Donor '18 thru '26
I just replaced my battery week before last.
Car sat for 2 weeks since it had been driven last and I had to jump it to go to a cruise-in.
Took it out and to Advance Auto for a test and sure enough it was going bad. Replaced with Optima Red Top this time.
I don’t fool around with a battery if it ever lets me down. These cars are so electronically dependent for everything to function properly, they can do some weird things when a battery isn’t right.
Old May 25, 2021 | 12:48 PM
katanaman's Avatar
katanaman
What would be the harm of setting the seats where you want them, then disconnecting the power to them, in the instance of seat modules not powering down after shutdown?
Old May 25, 2021 | 01:52 PM
knewblewkorvette
No harm at all. In fact, that's exactly what I did when my 98's passenger seat did this. I set it all the way back and unplugged it.
Old May 25, 2021 | 02:50 PM
Dbl_D718's Avatar
Dbl_D718
Generally no harm, but you do lose functionality associated with the seat control module. So obviously the seat memory no longer works, but neither does the telescoping wheel if you have that option. I can't remember if the mirror memory is tied to the seat control module or door control module. So, things you might not care about if you're the only one that drives the car.
Old May 25, 2021 | 03:14 PM
pauly1119's Avatar
pauly1119
St. Jude Donor '06-'11
I had bad luck with my last 2 red tops. They lasted less then 2 years. The Corvette is very voltage sensitive, a bad battery will play havoc.
Old May 25, 2021 | 09:37 PM
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
I bought it at Advance Auto and it has a 3 replacement warranty, so if that is the case it won’t be a problem.
They don't ask any questions if you have your receipt from when the battery is purchased. I just had that happen on one in my truck. Got a brand new one, and it is also has the same replacement warranty for 3 more years.
Old May 25, 2021 | 11:51 PM
jim993's Avatar
jim993
Check post # 10 in the following thread:
https://www.corvetteforum.com/forums...-w-tender.html
Old May 26, 2021 | 05:30 AM
Jistari's Avatar
Jistari
Red Tops are not what a C5 needs...
The original spec was for a RC of 90 (reserve capacity)...... it was revised to an RC of 120.
Any battery wit an RC of 120 would do better.
Nothing wrong with AGM batteries, as long as the RC is high enough.
And the leaking battery is something that did happen....about 20 years ago......so AGM isnt the be all and end all, modern batteries dont leak like that, fine if you want it, just make sure a dead draining wont kill it (as some AGMs do)....and use a battery tender (preferably a smart one like the Cteck 3000 or better) .
Old May 26, 2021 | 02:05 PM
Dave68's Avatar
Dave68
The originally installed AGM batteries that leaked were found to have been overtightened (clamps) at the factory, leading to cracks in the case. That issue was rectified and subsequent updates to the battery case pretty much eliminated the leaking issue.
My OEM 2001 C5's battery (AGM) lasted 6.5 years without any issues at all. Many Corvette owners installed catch trays to prevent leakage onto vacuum hoses under the battery, but those were mostly early-in-the-model change years and weren't required after the second generation batteries were installed in C5s like mine.
Old May 26, 2021 | 05:01 PM
Moved to C5 Tech.
To 2003 Battery problem
