DRL Lights Won't Work
Old Jun 2, 2021 | 01:25 PM
ls1wolf's Avatar
ls1wolf
Default DRL Lights Won't Work
My 1999 DRL's will not work. Yes, I'm one of those who love the look of the yellow lights! I have had the car for 18 months and can not figure it out. Thought I could live without it - but I just want them to work...
I have searched and searched and searched on the forum and seen a lot of good ideas - but nothing has worked yet. I'm up for anything else at this point.
The fuses are in place under the hood and in the passenger foot well. I have replaced both breakers in the passenger foot well also. Turn signals work just fine. I have the reverse lights and fog lights on when I unlock the car. I have replaced the turnsignal bulbs. I have replaced the corner lenses. The car does not have the automatic light sensor as its a low option car. Car is not tuned checked via HP Tuners, as I read somehow that can be tuned out - which I still can't figure out how... And lastly the emergency brake is not pulled one click. And lastly, its not a Canadian car.
I'm out of ideas - I just want the dang DRL's to work! ha - Any other possible ideas?
And of course - everyone likes pictures...
Thx
-Mark
Old Jun 2, 2021 | 02:08 PM
SilverC54me's Avatar
SilverC54me
There are 2 relays in the passenger foot well fuse block for the DRLs. Pull them one at a time and test.
There was something I read a long time ago about disabling the DRL by modifying the relay. This was in regards to making a US spec C5 compliant for registration in Europe.
Gary
Old Jun 2, 2021 | 02:16 PM
ls1wolf's Avatar
ls1wolf
Thanks Gary - Have replaced both relays as well.
Gary
Old Jun 2, 2021 | 02:31 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Have you physically inspected the light sockets? They are prone to corrosion at this point and may be the issue.
Old Jun 2, 2021 | 02:54 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Another idea, you may want to follow the wires back from the socket on the passenger side DRL. It should plug into a harness just above the fog light. Make sure that this doesn't have any corrosion, and is securely connected. You've already done everything else that I can think of. You might want to post this in the tech section to see if you can get any more responses.
Old Jun 2, 2021 | 03:30 PM
ls1wolf's Avatar
ls1wolf
So the turnsignal bulbs are NOT the same as the DRL bulb?
Old Jun 2, 2021 | 04:31 PM
Stingroo's Avatar
Stingroo
One is a 194, the other is a 4157. I think the 194 is the DRL.
I'm fairly certain of that anyway....
Old Jun 2, 2021 | 04:42 PM
MWWarlord's Avatar
MWWarlord
No they definitely are NOT the same bulb.
Old Jun 2, 2021 | 07:59 PM
SilverC54me
The main bulb (3157/4157) in the corner markers has 2 elements, one for the turn signal/DRL and the other for the parking lights. The other bulb is a 194 for the side markers.
If the turn signals are working properly up front then the bulb is good along with the socket.
What is the status of the 'brake light' on the gauge cluster? Is it on all the time? If so that will cause the DRLs to not turn on. Parking brake status signal is one of the inputs used to turn on the DRLs.
Gary
Old Jun 2, 2021 | 11:35 PM
Moved to C5 Tech.
Old Jun 3, 2021 | 07:33 AM
ls1wolf's Avatar
ls1wolf
Thx, Gary. Turn signals work.
No "brake light" on the cluster. I have pulled the brake one click and the light does come on - so thats not it either.
FYI, I do have these two codes:
B0502 - RH DRL Relay circuit
B0507 - LH DRL Relay circuit
Gary
Old Jun 3, 2021 | 05:50 PM
hron61's Avatar
hron61
Try cleaning the grounding point that the DRL circuit is on.
Bad grounds do weird things.
Let me look through my ground point notes on which ground handles which systems. brb.
Ok, it looks like the front marker and turn signal lamps ground is G104 which is near the battery, either under it or just to the side of it.
Old Jun 3, 2021 | 07:59 PM
SilverC54me
Did a bit of looking in the service manual. The B0502 and B0507 codes are for the control circuit for the DRL relay. There is testing instructions in the manual that I will post for you later tonight. The instructions do assume the use of a Tech2.
Gary
Old Jun 8, 2021 | 09:33 AM
ls1wolf's Avatar
ls1wolf
Gary
Any luck with those directions?
Old Jun 11, 2021 | 10:36 AM
jjc508520's Avatar
jjc508520
Something screwy with the E-brake - when e-brake is on the DRL's go off - correct?
To DRL Lights Won't Work
