PowerLoader II Question
Old Dec 16, 2002 | 04:56 PM
C5Fun's Avatar
C5Fun
Default PowerLoader II Question
I loaded the PCM in my 2000 A4 two years ago with Powerloader II mods. It's been great. I just had some work done on the car and the dealer reflashed the PCM (they called it being re-calibrated on the service report). Can I safely reload the PL II program? Or, is there a chance the GM may have made some changes to the PCM in this reflash that are incompatible?
Old Dec 16, 2002 | 05:07 PM
YO-EL's Avatar
YO-EL
Default Re: PowerLoader II Question (C5Fun)
You can re-install the PLII. It will overwrite what the dealer did, just like when you 1st installed it, and it overwrote the factory programming.
Old Dec 16, 2002 | 05:31 PM
vstella's Avatar
vstella
No problem..Download the PLII :yesnod: Just don't mod the car so that requires a reprogram by Steve Cole or your screwed!! :eek:
Old Dec 16, 2002 | 05:44 PM
C5Fun's Avatar
C5Fun
Default Re: PowerLoader II Question (vstella)
What do you mean by this??
Old Dec 16, 2002 | 06:01 PM
vstella's Avatar
vstella
Don't get me started on this..Bottom line Steve Cole forgot you after he delivered the PLII..There is NO customer support at all..PERIOD!
If you go with new gears, head and cam ..ANYTHING that requires a reprogram you might as well start shopping for a shop that does LS1 Edit or other options to reprogram the car..Steve Cole is NOT your man..nuff said! :yesnod:
Old Dec 16, 2002 | 06:05 PM
C5Fun's Avatar
C5Fun
Thanks for the info .... I had thought that for a fee ~$150 he would make changes upon request .... what happened?
Old Dec 16, 2002 | 06:07 PM
MTWallet's Avatar
MTWallet
In other words, he laughed all the way to the bank!:steering:
It would be kind of nice to know what part of the program the dealer upgraded in your PCM.
Old Dec 16, 2002 | 06:13 PM
C5Fun's Avatar
C5Fun
Default Re: PowerLoader II Question (MTWallet)
Don't know, but the A4 mods are gone for sure ... just assumed they did a complete reflash. What would be the normal procedure for a dealer? Can/Do they reflash sections of the PCM code typically?
Old Dec 16, 2002 | 08:49 PM
vstella's Avatar
vstella
Not necessarily :rolleyes: You can still install some real SOTP A4 mods without a reprogram.. :yesnod: Do the Pro torque 2800 converter and Transgo shift kit ..You will love it...I PROMISE!!!..The PLII already removed the torque management system..now take advantage !!
Do it..You can thank me later :yesnod:
Old Dec 16, 2002 | 11:58 PM
SilverStar's Avatar
SilverStar
:iagree: You will never hear from Steve once he has you $$$. Forget about mods with Steve.
Old Dec 17, 2002 | 07:27 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Reload and enjoy............... :D
To PowerLoader II Question
