Steering column lock issue.
Old Jun 24, 2021 | 07:44 PM
BryceU_C5's Avatar
BryceU_C5
Default Steering column lock issue.
As a Precursor: I've spent a good bit of time looking for someone with the same issue as me and I didn't see anything quite like I've got going on.
So I first had this issue a couple weeks ago where I got the dreaded "service steering column lock" "pull key wait 10 seconds" messages at a gas station of all places. I reset the BCM and looked deeper into the issue when I got home. I came to the conclusion that I needed an LMC5 bypass switch. Seemed logical. I installed it and at first no problem, worked a couple more days and had the issue come up again. Then I found out my battery was kinda old so I just replaced it the other day with an optima. Today I just had the issue come up again and idk what to do next besides replace the BCM. Help?
Old Jun 25, 2021 | 08:18 AM
rrwirsi's Avatar
rrwirsi
Bid you do the Brown Wire connection? If not, do it. See your LMC5 instructions. If yes, call Richard (855-565-8388) at Compliance Parts. He is #1 in customer service.
Old Jun 26, 2021 | 12:31 PM
slm427's Avatar
slm427
I'll second reaching out to Richard - superior customer support. I experienced the same issue w/ mine, even after doing the "brown wire mod" and replacing the battery. The issue was most prevalent when I was in a rush, jumping in to the car and immediately starting it up. Richard's advise was to turn the to ignition to the on position, wait until the gauges "cycle", then start the car. This solved the issue w/ mine. Richard described it as a "lazy BCM", that doesn't receive the signal soon enough.
Old Jun 27, 2021 | 09:25 PM
Dbl_D718's Avatar
Dbl_D718
As mentioned, do the brown wire portion of the LMC5 install if you haven't already. Otherwise, keep the battery charged if the car is sitting for more than a couple weeks. And ultimately, the "pull key wait 10 seconds" thing is probably still going to happen occasionally. I think it's just a quirk of these cars to some extent, so pull the key, wait, and restart and you at least shouldn't get stranded with the LMC5 installed.
Old Jun 28, 2021 | 07:25 PM
royal flush's Avatar
royal flush
Without doing the brown wire--if people would insert key and let the tach sweep than start car--you wouldnt get the any messages !!
Old Jun 28, 2021 | 08:12 PM
royal flush
Originally Posted by slm427
i'll second reaching out to richard - superior customer support. I experienced the same issue w/ mine, even after doing the "brown wire mod" and replacing the battery. The issue was most prevalent when i was in a rush, jumping in to the car and immediately starting it up. Richard's advise was to turn the to ignition to the on position, wait until the gauges "cycle", then start the car. This solved the issue w/ mine. Richard described it as a "lazy bcm", that doesn't receive the signal soon enough.
this is the answer to the problem!! LET the guages sweep -5 seconds- than start car--wella no more problems or messages--also KEEP battery charged up driving car or on a charger-
To Steering column lock issue.
