true stock trim height
Old Dec 17, 2002 | 07:57 PM
tom p's Avatar
tom p
Default true stock trim height
can anyone give me true stock trim height,that is at 30psi all around ,from ground to fender lip ,using the hub as center axis?
I know standard trim is measured from lower ball joint to center bolt on lower control arm, but accurate distance is very tough to get ,considering you got to use a bubble level.
I am finished installing coils and new bars, but before a trip to the alignment guy , i like to get everything even. I figured i only dropped it about a inch .which is fine, but there has got to be an easier way to measure trim ,other than GM method. By the way ,new chrome o6's and 275/295 g-force just mounted-----looks sweet----run craps are history-pix to follow--can't wait till spring --- winter sucks in NY when ya got this sittin in the garage and 6+ inchs of white on the ground. [IMG][/IMG] :reddevil [IMG][/IMG] :sleep: :sleep: :sleep: :sleep: :blueangel:
