P0171B Code
Old Jul 15, 2021 | 07:56 PM
zumbahlenm's Avatar
zumbahlenm
Default P0171B Code
I keep getting P0171B (bank 1 system to lean) code coming on and off.
Sometimes it will go away on its own from driving. Ive been researching possible problems. I can see the Air intake doesnt seat properly. The rubber sponge gasket doesnt sit properly. The top part that clamps down is missing a clamp. Would this stem the problem? I also noticed two holes were drilled into the rear exhaust after the muffler to give it some sound. Would that cause it?
Old Jul 15, 2021 | 08:24 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Your P0171 (bank 1 lean) is likely caused by your poor intake seal…your bank 2 is most likely running lean also but your fuel trim on bank 2 isn’t high enough yet to cause a P0174 !!…rear exhaust holes will NOT cause this code to set. It’s a good idea to fill out your profile so if in the future you have some issues we can see what year, mods, etc you have…this is especially important when it comes to wiring differences.
Old Jul 15, 2021 | 08:52 PM
zumbahlenm's Avatar
zumbahlenm
Ok great. I'll do that.
The housing is definitely not sealed correctly. It's more of the base housing...do you know where I can buy one ? I didn't see anything on quick google search. Is it easy to change?
What about switching to the dual filter Y pipe I've seen on ebay. ?
Old Jul 15, 2021 | 08:59 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
I wouldn't switch to the dual cone intake, personally. It doesn't add any performance benefit and leaves the filters exposed.
Take a photo of what you're describing and we can probably find what you need.
Old Jul 15, 2021 | 09:42 PM
popshumphrey's Avatar
popshumphrey
St. Jude Donor '16
Old Aug 26, 2021 | 03:02 PM
zumbahlenm's Avatar
zumbahlenm
Ok. I took some pictures of current set up.
The gasket doesn't even have a surface to seat on ? How would I fix this?
Old Aug 26, 2021 | 03:10 PM
C5 Diag's Avatar
C5 Diag
No idea of what I’m looking at here but any seal, clamp etc downstream of the MAF has to be sealed…the air filter or any sealing surface upstream of the MAF sensor will not cause a P0171/P0174 !!
Old Aug 26, 2021 | 03:15 PM
zumbahlenm's Avatar
zumbahlenm
That is the square box that the intake filter sits on. I think I need a new housing?
Old Aug 26, 2021 | 03:18 PM
C5 Diag's Avatar
C5 Diag
A leaky air filter will not cause the lean code…it is upstream of the MAF…if you are still getting a lean code you need to look elsewhere !!
Old Aug 26, 2021 | 03:25 PM
zumbahlenm's Avatar
zumbahlenm
Ok I just had the intake manifold Seal done. I'm not sure any other common areas..
Old Aug 26, 2021 | 03:42 PM
C5 Diag's Avatar
C5 Diag
The FIRST thing I should have asked is had any maintenance been done…now that your saying the intake manifold was off…I’d look at those seals !!
Old Aug 26, 2021 | 03:48 PM
zumbahlenm's Avatar
zumbahlenm
ok, the code was doing it before the seals were worked on. I had the intake manifold seals and oil pan gasket done because it was leaking oil...i dont understand how intake manifold seal would leak oil but it is what they told me.
Old Aug 26, 2021 | 03:53 PM
C5 Diag's Avatar
C5 Diag
I would bring it back to your shop and if they have a smoke machine they should be able to find the leak !!..an intake manifold leak would not cause an oil leak.
Old Nov 20, 2021 | 09:17 AM
zumbahlenm's Avatar
zumbahlenm
I found the problem. There is a break in this hose line. What is this hose that connects to both sides of engine.
Old Nov 20, 2021 | 09:22 AM
Stingroo's Avatar
Stingroo
That's your PCV hose. That would definitely cause smoke and an oil smell.
Old Jan 13, 2022 | 04:42 PM
zumbahlenm's Avatar
zumbahlenm
Ok I changed that whole PVC assembly.
Everything worked great.
Now I accidentally overfilled the gas tank and immediately when I turned it on it thru a p0171 code again. Is a weak gas cap seal or housing flange a possible reason to cause that? Ive heard of gas caps causing check engine lights.
Old Jan 13, 2022 | 05:22 PM
popshumphrey
St. Jude Donor '16
I really want to hear what C5diag says, but, overfilling should not cause the code. The gas cap can cause an engine light to come on but not necessarily the lean codes. However, I would make sure the gas cap is tight, reset the code, drive it and see if it comes back up. Good luck, and do what the other guys say. They are great. But make sure the gas cap is tight.
To P0171B Code
Old Jan 13, 2022 | 05:29 PM
C5 Diag's Avatar
C5 Diag
A gas cap will not cause a lean code…it will however cause an EVAP code…the PCV we assume is not causing your issue…I’d let your mechanic who should have a scan tool check your intake manifold gaskets but then again you said you had this issue prior to the gasket change…is this why he changed the manifold gasket ??…if he did he should have cleared the codes and then check his fuel trims to verify the repair…he should be able to diagnose this easily..if not he can contact one of us here on the Forum…don’t shot gun parts unless you gather some evidence and make an accurate diagnosis using scan data…at least you will be able to tell if it’s bank specific, a vacuum leak involving one or both banks, a MAF or a fuel delivery issue.
Old Jan 13, 2022 | 07:44 PM
69's Avatar
69
Cruise-In VI Veteran
After reviewing this post, can you please post the model year of this car as there can be variances in troubleshooting fault codes by model year cars?
Regarding the OP post #6, that is a Varam Intake system and the airbox latch is broken off...details of this air intake system here VR-B2 (vararam.com)
As I too have this intake system, the Mass Airflow Sensor (MAF) installation is very specific in placement/orientation and could allow unmetered air into the intake if not properly installed.
Detailed install instructions here.pay attention to MAF installation steps 10 thru 14...
http://www.vararam.com/VR-B2_instructions.pdf
OP Latch broken off
Cheers,
Goose
Old Jan 15, 2022 | 10:26 AM
zumbahlenm's Avatar
zumbahlenm
Thank you, I will have to check that out! The check engine light comes on and off after certain mileage..
@69 Did I see a 68 Tom Mcewen mongoose dragster on meecum kissimee yesterday? Same logo..
