Lug Nut torque?
Old Aug 23, 2021 | 11:09 PM
Alley Oop's Avatar
Alley Oop
Default Lug Nut torque?
How much do you torque the lug nuts on a C5?
Thanks in advance.
Mark
Old Aug 23, 2021 | 11:15 PM
rjacobs's Avatar
rjacobs
Old Aug 23, 2021 | 11:35 PM
Alley Oop's Avatar
Alley Oop
Thanks rjacobs.
Cheers,
Mark
Old Aug 26, 2021 | 07:39 AM
wydopnthrtl's Avatar
wydopnthrtl
On all my cars for 30+yrs I clean the threads w/a plastic toothbrush, add 1 drop of engine oil at the end of the stud, and TQ to 90ft lbs. Seems to make install and removal TQ very consistent. Only time I ever get a weeping of the oil is if the brakes get real hot.. which is very seldom. (this is for acorn nuts only)
Old Aug 26, 2021 | 11:41 AM
Alley Oop's Avatar
Alley Oop
Thanks for the tip wydopnthrtl (I like your handle). I've used a extremely light coat of grease on the bevel of the lug nut just to make installation easier.
Cheers,
Mark
Old Aug 26, 2021 | 12:12 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Cheers,
Mark
do not put grease on the threads or nut...it interferes with the torque...
Old Aug 26, 2021 | 12:55 PM
Alley Oop's Avatar
Alley Oop
Yello95, it makes sense to me that it would interfere with the torque. It would reduce the friction between the lug nut and the rim. I can live without the greased lug nut knowing that I had the correct torque.
Cheers,
Mark
Old Aug 26, 2021 | 06:25 PM
Alley Oop's Avatar
Alley Oop
Thanks SweenyRod, I am listening to the voices of the experienced. Never used to, but age and too many errors can actually be an education.
Cheers,
Mark
Old Aug 26, 2021 | 07:14 PM
UM Rebel's Avatar
UM Rebel
Thanks in advance.
Mark
I torque to 100. Drive for a couple of days then re-torque. Re-torque may not be necessary. It’s just the way I learned to do it.
Old Aug 26, 2021 | 07:37 PM
Alley Oop's Avatar
Alley Oop
UM Rebel, the re-torque in a couple of days is a great idea. After I read your post, I remember reading about a re-torque many moons ago. Thanks.
Cheers,
Mark
To Lug Nut torque?
