Reduced Engine Power
Old Sep 11, 2021 | 02:20 PM
vankouwenhoven's Avatar
vankouwenhoven
Default Reduced Engine Power
Hello I have own my 1999 C5 for a while but the other day I got side swiped long story short I pulled over and turned the car off and the lady ran off without stopping. when I proceeded to turn the car back on .... nothing ... all the lights came on but it wouldn't crank. I hear the fuel pump prime but nothing from the starter. I have checked all the fuses and none of them are blown. I started checking code and I have a few that concern me
U1040 H
U1064 H C
U1160 H C
U1176
I know that H and C are historical and current
My display also says "Reduced Engine Power"
Thank you in advance for any help I have read these forums but have never posted anything so any tips would be helpful
PS is have also tried resetting the PCM by putting the positive and negative cables together but to no avail
Old Sep 11, 2021 | 03:02 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Welcome to the Forum and sorry about your accident !!…where did the car get hit ??…looks like you have “no comms” with the EBCM, BCM, DDM, and the RCDLR…if any of these modules are near to where the damage is I’d start looking for some possible wiring issues !!
Old Sep 11, 2021 | 03:07 PM
vankouwenhoven
It was right where the gas cap is and it was only a tap I don't know if they have a fuel shut off or anything but I kind of ruled that out because I hear the fuel pump prime every time I try to turn it on
Old Sep 11, 2021 | 03:43 PM
C5 Diag's Avatar
C5 Diag
The Remote Control Door Lock Receiver (RCDLR) is located near the gas cap area…there may be some issues with your serial data bus from that module…for now remove fuse 27 in the IP Fuse box (HVACCON)…that fuse powers the RCDLR…see what happens ?…also does your key FOB work ??
Old Sep 11, 2021 | 04:00 PM
vankouwenhoven
I will do that right now what page and and volume is that in the service manual I have all three of those and I didn't see that
Old Sep 11, 2021 | 04:04 PM
C5 Diag's Avatar
C5 Diag
That is from my 01 FSM…volume 3 page 8-662…keyless entry chapter !!
Old Sep 11, 2021 | 04:15 PM
vankouwenhoven
So I tried pulling that fuse and nothing changed also when I try to turn it to start none of the gauges go down like normal just nothing happens ... no clicking nothing
Old Sep 11, 2021 | 04:23 PM
C5 Diag's Avatar
C5 Diag
If you turn the key on do the windows work ??…is all you see on the DIC is reduced power ??….open the driver door and shake the rubber boot…there is a connector under there where we have some wiring issues !!…for now try that !!
Old Sep 11, 2021 | 04:31 PM
vankouwenhoven
No the windows do not work neither does the radio. And no the entire gauge cluster comes up and acts normal
Old Sep 11, 2021 | 04:33 PM
C5 Diag's Avatar
C5 Diag
With key on does your fuel show E ??…is your water temp gauge maxed out ??
Old Sep 11, 2021 | 04:41 PM
vankouwenhoven
Nope fuel gauge has fuel in it and the temp and oil psi are at 0 cause it isn’t on
Old Sep 11, 2021 | 04:44 PM
C5 Diag's Avatar
C5 Diag
With a short to power or to ground on the serial data line (how all the car modules communicate with one another) you will see that with the key on !!…water temp…not oil pressure !!
Old Sep 11, 2021 | 04:51 PM
vankouwenhoven
Could you explain that last response a little more ?
Old Sep 11, 2021 | 04:55 PM
C5 Diag's Avatar
C5 Diag
I have to run out…you talking about the serial data network…maybe someone else can chime in !!
Old Sep 12, 2021 | 12:45 PM
oelarse's Avatar
oelarse
To verify if something is "killing" your serial data you can check the 0-7 volt signal with a scope ( first photo) or second best a DVOM approx 0.4 volt
It is best to use a scope to be able to view a stable pulse signal like the one below .
If you have a bad connection(partly broken wire ) corrupting the serial bus it is hard to confirm without a scope .
You can try to disconnect the 3 wire star connector in passenger footwell . This will disconnect both door modules and the seatmodule and then see if it make any difference on the non starting issue .
You can also check if the Body Control Module energize (grounding) the TDR relay when you try to start the engine .
Measure between a Ground point and the A1 side of the TDR you shalll measure 12volt with ignition ON .
When you press START the A1 side of the TDR will drop to 0.1-0.2 volt when the BCM energize this relay by grounding A1 side of the relay .
If the TDR energize the relay correctly the C1 to A2 relaycontact will now close and you shall measure 12 volt from MaxiFuse 52 on the A2 (PINK wire) of the TDR relay
Old Sep 13, 2024 | 07:47 AM
ohc's Avatar
ohc
4th Gear
https://youtu.be/f_NEEdgZSlE
this is exactly whats happening to my car. Whats the problem and how expensive is the fix?
Old Sep 13, 2024 | 07:49 AM
ohc's Avatar
ohc
4th Gear
i just started my car again and it started like normal, but all yesterday it would not start and did that.
Old Sep 13, 2024 | 07:50 AM
C5 Diag's Avatar
C5 Diag
Can’t exactly tell you what your problem is and the cost !!…take your car to an auto electric shop.
To Reduced Engine Power
