What is this called hvac
Old Oct 28, 2021 | 10:55 PM
Harleyrocker's Avatar
Harleyrocker
Default What is this called hvac
I took my fender off and both lines when i blow through have a hole right under battery where it F'n leaked. Ughhh. I need to know what this is called so i can order one.'the line in the top just broke off
its real brittle . The bottom line
broke trying to take it off. This is the part I need .
Old Oct 29, 2021 | 05:44 AM
VetteMed's Avatar
VetteMed
It's a vacuum check valve tee, but I don't know if that's how it's described in the parts lookup. I'll dig around a little and post back if I find anything.
Edit: PN 15733271 is the service replacement.
Old Oct 29, 2021 | 06:32 AM
Harleyrocker
Cool thanks .'
Old Oct 29, 2021 | 08:35 AM
Napoleon_Tanerite's Avatar
Napoleon_Tanerite
Well, I guess this explains your mystery HVAC issues you were posting about the other day.
Old Oct 29, 2021 | 08:56 AM
Harleyrocker
It sure does . The battery was new in march of this year . Really pisses off . I put a optima back in it . Like a fool i replaced an old optima tor the POS diehard and look what that got me.
Old Oct 29, 2021 | 11:00 AM
grinder11's Avatar
grinder11
It's an acronym for Heat, Vacuum, & Air Conditioning. This is obviously the 'V' part.
Old Oct 29, 2021 | 11:04 AM
Harleyrocker
Lol yeah i know what hvac means , i tried to edit title but i couldnt get it to change .'i was meaning what is that piece called so i can get another one
Old Oct 29, 2021 | 11:22 AM
VetteMed's Avatar
VetteMed
Actually, the V stands for Ventilation, not vacuum.
Old Oct 29, 2021 | 03:40 PM
grinder11's Avatar
grinder11
Right. Well I got two outta 3!! I knew it, too. Stuff happens. Thanks for the correction. Sorry about that. Vacuum.....DUH!!😞
Old Oct 30, 2021 | 06:32 PM
irfgt's Avatar
irfgt
It used to be called the cruise control vacuum check valve. They usually carry them on the "HELP" rack at most Auto parts stores.
To What is this called hvac
