which Z06 intake?
Old Dec 27, 2002 | 12:38 AM
slxrti's Avatar
slxrti
Default which Z06 intake?
I'm looking for a ZO6 intake, Do they come with/without a egr fitting.
My vett is a 2000, and I'm located in calif. I still need to pass the visual.
slxrti :jester :conehead
Old Dec 27, 2002 | 02:48 AM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: which Z06 intake? (slxrti)
All the intake manifolds on the C5 are the same since 2001 whether its an LS1 or LS6.
The C5 has never used an EGR valve like the F-body even tho otherwise the intakes are the same.
The one exception is that some 2001 manifolds experienced a whistling sound under accelleration, which was fixed under warranty with a new manifold for all C5's (LS1/LS6). The new manifold has been used since 2002 in all C5's. But again its no different than the 2001 unit, other than the whistle sound corrected where necessary.
[Modified by kewlbrz, 1:49 AM 12/27/2002]
