Intake R & R Pointers Wanted
Old Jan 11, 2022 | 05:33 PM
spfautsch's Avatar
spfautsch
Default Intake R & R Pointers Wanted
Recently acquired this gem [link] to take daily driver duties during daylight savings time.
I've been going over it and correcting all the little issues such as parking brake adjustment, HID ballast resistor so the headlight doors will close, de-blinging, etc.
Two of the issues dinger clued me in on were a P0410 A.I.R. code and that the vent control doesn't work (air only blows out the dash vents).
I've deduced from the symptoms that the vacuum line on the back of the intake is either disconnected or broken. It wasn't difficult, because I can plainly hear it (as did my buddies who are professional mechanics).
Being an LS virgin, I searched this forum and found essentially nothing about R & R'ing the intake on this thing. I'd be eternally grateful to have some pointers so I don't end up with the car still sitting in pieces tomorrow afternoon when my wife gets home from work.
I do have the FSM and I will break it open if necessary, but was hoping someone might have some quick & dirty pointers / warnings that avoid all the unnecessary verbiage contained in said document. I've pulled the engine out of my '95 C4 more times than I can recall, clearanced the block for a stroker crank, etc., so you're not talking to Gomer Pyle here.
Old Jan 11, 2022 | 06:42 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
It's actually pretty easy, since there's no water crossover, like the older small block Chevy engines. One key thing is that the rear most bolts won't clear the intake manifold bosses, as they'll contact the underside of the cowl, before they can be removed. Lift them, then use a long rubber band, to keep them in the manifold bosses, but disengaged from the cylinder head. A popular "while I'm in there", is to replace the oil pressure sending unit, as it's a LOT easier to access with the intake removed, and it's a known part to fail.
Old Jan 11, 2022 | 07:50 PM
spfautsch's Avatar
spfautsch
Thanks for the pointers!
I see what you mean on the rear bolts. I'll be making some standoffs for those out of some 1/4" pvc supply line to make installation simpler.
As I pulled the manifold out it became apparent the cause of this one was evidently the previous replacement of the aforementioned oil pressure sender. It's all shiny and new compared to everything else under there. And apparently the dipsh1t that did the job didn't bother with the vacuum connector in question.
Super simple fix.
The easter egg in the job is that I'm seeing these heads have been CNC ported. Me likey! :-D
Old Jan 11, 2022 | 08:01 PM
mmartinez's Avatar
mmartinez
You might add a little extra piece of vacuum hose to make that connection.
Old Jan 11, 2022 | 08:38 PM
spfautsch's Avatar
spfautsch
Went one better and just replaced the whole plastic garbage thingy with a regular vacuum line to the check valve.
Thanks guys!
Old Jan 12, 2022 | 12:15 PM
leadfoot4's Avatar
leadfoot4
Originally Posted by spfautsch
..........As I pulled the manifold out it became apparent the cause of this one was evidently the previous replacement of the aforementioned oil pressure sender. It's all shiny and new compared to everything else under there.
Does that "shiny and new" oil pressure sender have a silver plated body, or a brass colored one. The brass ones are the preferred ones.....
Old Jan 12, 2022 | 12:38 PM
grinder11's Avatar
grinder11
Rubber band, or some guys have used clothes pins!!
Old Jan 12, 2022 | 05:53 PM
spfautsch's Avatar
spfautsch
Thanks guys. The intake went back on without a hiccup. In the grand scheme of things that piece of the project was less trouble than getting the car up in the air to change the oil.
No brass body oil pressure sender, so I guess I'll be revisiting that in the future. But, the intake was so easy to R & R I don't consider that a problem. Pulling the headlight and quarter panel to access the vacuum reservoir was far worse.
My gut tells me the driveshaft couplers are toast in this one, which is what I fully expected going in. That job is gonna suck 10x worse. Any volunteers? :-)
Old Jan 13, 2022 | 01:45 PM
kh400's Avatar
kh400
Default intake
Also, make sure you clean the dirt around the intake before removal with a vacuum or compressed air to keep crap out of the intake runners.
Old Jan 14, 2022 | 11:49 AM
grinder11's Avatar
grinder11
You're absolutely correct on how easy the intake is to R&R. Easier than an oil change. Makes me wonder why anyone would put a hole in there cowl to access the oil sender. There's no easier intake to remove on any car I've ever worked on.
To Intake R & R Pointers Wanted
