I f you're installing a new balancer that already has a keyway, would you try to line up your pinning kit to use that keyway, or would you drill through "virgin" part of the balancer ??
The pin that you use after drilling the balancer is much smaller than the keyway typically used in aftermarket balancers. It might work if the balancer spins on the crank but is less than ideal IMO. Are you pinning the crank because you are going FI?
Yes
If you try and drill where the keyway is I think you run the risk of the drill bit grabbing and breaking.
When I pinned mine I drilled the pin hole like 90 degrees away from the keyway. Also packed the aftermarket keyway with silicone and smear some silicone on the washer face when torquing it back on.
TIA
AJ
The pinning kit that I used, had a means to locate itself on the crank snout, indexing off the keyway, which correctly indexed the location for the pin to be drilled.....
I'm in the middle of this, out in the garage by myself. My wife opens the garage door and says "are you talking to yourself"? Of course i say no. I'm talking to this (insert profanity) car!
As someone previously recommended, I put the wrenches down for the day and came in for a beer.
At least I only burned myself once on my drop light today
I'm in the middle of this, out in the garage by myself. My wife opens the garage door and says "are you talking to yourself"? Of course i say no. I'm talking to this GDMF'in car!
I don't want to be sarcastic, but as you're learning, this is a job that can't be rushed, if you want to do it right. I have the benefit of A) being retired; and B) having another vehicle as a daily driver. If i remember correctly, this replacing the balancer and pinning the crank job, took me about 3 days, working at a leisurely pace.
There is a vid out there on you tube where a guy did what you are asking. He did say that the drill bit was bigger than the keyway and it worked out for him......But, it may just be best to seal the keyway as mentioned and start from scratch......I may be in the same boat as you. I have a bad HB and may have to get the summit 5201 balancer as the powerbond PB1117N (no keyway) has been on backorder for months now...
I was lucky and found a local forum member with a side pinning tool and used that method to pin my crank to the dampener! IMHO, That is the way to do it. It was easier than it looked to be.
IF,, it was ME, I would try to use the same hole, but, that's ME.
I use a heat gun and heat the dampener hub to about 200 degs right before installation. It goes on much, much easier. Also, dont forget to put oil/lube on the snout where the cover seal makes contact with the snout.
The side pinning kit puts a pin in that the keyway can slide over, like a key. The front pinning kit would use an unkeyed or the unkeyed area of a balancer.
Amazon had them until about 3 days ago…. I ordered on Summit and they said it will ship on March 2.
Fingers crossed!
The Amazon vendors did not have them even though they said they were in stock. I know because I called them...As for Summit, they will be getting 45 balancers on March 10th and will ship out on the 14th....I actually called dayco/ powerbond to see what the deal is....that's where I got my info and did call Summit to confirm this. These have been on backorder since Oct....Hopefully there are no delays in shipping and they actually do ship out to us on the 14th...
