PCV Mod
Old Jan 3, 2003 | 07:02 PM
hrdtopv8's Avatar
hrdtopv8
Default Re: PCV Mod (Patches)
Pep Boys, Lowes, Home Depot have been known to carry them. :cheers:
Compressor filter from Wally World and the 3/8" OD 3/4" ID fuel hose from Sears... :D
Old Jan 4, 2003 | 04:21 PM
David Plum's Avatar
David Plum
Default Re: PCV Mod (skidmarc)
Best fix for this is to install ls6 valley may need to modify block for fit . And install z06 vacuum harness . Short harness from t/b to valley block off both rear valve cover ports w/vacuum caps or tee one side into new harness for sufficiant crankcase vent . Did myself 2 hours tops
Old Jan 4, 2003 | 11:46 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Dave Plum
Can you show us some pictures of this ZO6 PVC mod that you did.
Bill
Old Jan 5, 2003 | 12:08 AM
SlumpinC5's Avatar
SlumpinC5
Sorry guys but I think I'm missing something here... If the oil is not trapped by the filter where is it going and what damage is being done?
Old Jan 5, 2003 | 02:02 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: PCV Mod (Black_C5)
Black C5
It goes straight into the intake and gets routed to each cylinder!!! :rolleyes: You will also see it as as a nasty mess on the back of your throttle body blade.
That is why alot of people are doing MODs to collect it prior to it getting into the intake.
The LS6 has a new and improved PVC system. I guess GM got wise to the fact that it was a problem! My mod will be installed SOON :thumbs:
Bill
Old Jan 5, 2003 | 02:11 AM
SlumpinC5's Avatar
SlumpinC5
Default Re: PCV Mod (Bill Curlee)
Hummm I see sounds good... This dosent affect performance or anything huh...
Thanks for the help.
Old Jan 5, 2003 | 02:25 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Any time that you add engine oil to the combustion process it isn't a good thing. The oil from the PVC system gets past the PVC baffel when you do alot of high revs on your engine. Under daily driving you only get a small amount. I dont want any so I'm going to do the mod. You may see some in your intake manifold if you remove the air bridge, block the throttle open and look inside with a flash light.
Does it hurt anything???? Ehh,, I doubt it if you only drive normally. I drive HARD :thumbs: DAILY!!!! I do get alot of oil in the intake :yesnod:
Look inside your intake and form your own opinion. Let us know what you find and if you want the MOD.
Bill C
Old Jan 5, 2003 | 06:17 PM
David Plum's Avatar
David Plum
Bill it was necc. to remove a section of the block you will need to stuff rags to protect engine . Look on ls1.com is where they have pictures of block mods I did this mod while I was o/h engine easy to clean up. no more oil problems!
Old Jan 6, 2003 | 07:35 AM
Rx7Rob's Avatar
Rx7Rob
Default Re: PCV Mod (David Plum)
I also did the mod to my 2000 a few months ago. If I'm hard on the throttle, it seems to be collecting oil. Anything less than WOT and its mainly condensation.
Old Jan 6, 2003 | 08:58 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Dave
What mod are you talking about that needs block grinding? I was just going to add the in-line filter in the PVC hose. If there is something that Im missing please let me know. What do I look for on LS1.com?
Interested!
Bill C
Old Jan 6, 2003 | 09:41 PM
David Plum's Avatar
David Plum
Bill go to ls1.com as about pcv mod change over to ls6. Consist of new valley pan baffle on bottom hits block they have pictures what to do. and ls6 harness
Old Jan 6, 2003 | 09:57 PM
magragc5's Avatar
magragc5
Default Re: PCV Mod (vette#one)
Heys guys, didn't you read the liturature. This is called the two stroke add oil to your gas feature. It is crutial for proper lubrication of internal engine parts! :lol: :lol: :lol: :lol:
