LS1 engine missing
Old Feb 5, 2022 | 08:16 PM
grayman1950's Avatar
grayman1950
Default LS1 engine missing
2003 ls1 when I power brake it, the engine starts miss firing about 1500 rpm it seems to drive fine.New plugs and wires. I did install a twin snorkel air systrem and it moved the mass airflow sensor down a little further could that be it? When you start to brake it , starts smooth then it's like you hit a switch and starts missing back off the gas and it soothes out.
Last edited by grayman1950; Feb 5, 2022 at 08:20 PM. Reason: I never know if I did this right, Why do you make this so hard to ask a ?
Old Feb 5, 2022 | 08:32 PM
Justin Raney's Avatar
Justin Raney
Do you have any videos of this power braking? I've never done this but would be curious as to what it looks like on camera. Is this a method used at the track for launching without line locks?
Old Feb 5, 2022 | 11:10 PM
jim993's Avatar
jim993
Sounds like a vacuum leak in the intake- or the brake booster and hose system.
Did you modify the MAF in any way?
How far and how was it moved?
What codes are reported?
Old Feb 6, 2022 | 05:44 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
As was mentioned check to see what DTC’s are stored (probably a P0101)…is the MIL illuminated ??… these aftermarket filters can certainly cause these lean misfires and the PCM will be able to adapt its fueling strategy over time but sometimes not…check to be sure all your connections to it are secure and not leaking.
Old Feb 6, 2022 | 08:51 AM
helga203's Avatar
helga203
You didnt even know it, but u made a (two-step rev limiter)
Old Feb 6, 2022 | 04:04 PM
grinder11's Avatar
grinder11
LMAO!!!
Old Feb 8, 2022 | 09:55 AM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
I hope you find it.
Old Feb 9, 2022 | 09:17 AM
Robert Barcus's Avatar
Robert Barcus
When I first saw the title I thought...What do you mean LS1 missing? You opened the hood and it was just gone???
To LS1 engine missing
