Fuel Trim
Old Feb 28, 2022 | 05:14 PM
Swens's Avatar
Swens
Default Fuel Trim
I've worked with a lot of scan tools over the years. On the German brands when a hard fault is cleared the short and long term fuel trims were reset automatically.
It was good to see an immediate change in short term trim after a related repair.
With our cars is the same true? A fault clear via the DIS or scan tool, or a manual reset? Or at all?
I just replaced all of my hardened injector seals. The engine runs smoother for sure. Just would be nice to confirm the change and by how much.
Old Mar 1, 2022 | 07:48 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
When my C5 has problems with the fuel trims because of a Vararam install. I thought resetting the codes from the DIC reset the fuel trims but that's not true. Just checked it
Old Mar 1, 2022 | 08:23 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
The fuel trims will not reset if a DTC is cleared…if you have a decent scan tool you should have a “fuel trim reset” usually under “special functions”.
Old Mar 1, 2022 | 08:24 PM
Swens's Avatar
Swens
Would love to have one.
Old Mar 1, 2022 | 11:40 PM
C5MSG2004Vert
If you need to reset the LTFTs just disconnect the battery for a few minutes. After removing the battery cables you can touch the cables together to assure all voltage has been removed from the PCM.
Old Mar 8, 2022 | 12:12 AM
douglasjre's Avatar
douglasjre
Would this reset the radio so it no longer works
Old Mar 8, 2022 | 03:06 PM
C5MSG2004Vert
As long as the radio lock is disabled in the radio there won't be a problem. The steps are in the manual.
To Fuel Trim
