rear defroster wire
Old Mar 2, 2022 | 10:15 PM
Justin Raney's Avatar
Justin Raney
Default rear defroster wire
My rear defroster wire is old and brittle leaving some exposed wire. I want to replace the the exposed coily wire with new coily wire. Does anyone know where to get the correct wiring? Its for the power supply to the middle rear hatch. I found these for 18$ but im not sure if theres a better ebay or amazon seller.
Defroster coil cords for flip up rear glass
Old Mar 4, 2022 | 08:25 AM
Justin Raney
Ok someone had told me this is the defroster or antenna wire? Theres 2 one on the passenger side of the rear window and one on the middle. So ones for the defroster and ones for the antenna?
Old Mar 4, 2022 | 09:59 AM
mmartinez's Avatar
mmartinez
The middle coil wire is the antenna, the wire that comes from the strut is your defroster power.
Old Mar 4, 2022 | 10:01 AM
Justin Raney
Great thanks man do you know if its just standard 16-18 gauge wire or is there a special wiring that antenna uses? This place sells rear defroster wire coily like the antenna wire for 18$ do you think it will still work or is antenna wire special. The wires are about the same style. It looks like standard exposed copper coil wire if you ask me and this place that sells rear defroster coiled wire for 18$ should work the same?
Old Mar 4, 2022 | 10:40 AM
mmartinez's Avatar
mmartinez
Will work the same, antenna wire has very small signal, wire gauge is not important.
Old Mar 4, 2022 | 01:37 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
I'm thinking that the antenna wire is a shielded coax and it has a certain impedance. So just replacing it with a straight wire might not be such a good idea. If it's just a piece of wire go ahead and replace it.
Old Mar 4, 2022 | 02:19 PM
Justin Raney
I thought so too but looks like straight copper thin wiring. They sell spray electrical tape i dont know if could recoat it.
To rear defroster wire
