View Poll Results: Should i do it
Yes you'll finish it in time
70.00%
No its impossible
30.00%
Voters: 10. You may not vote on this poll
Harmonic balancer need advice!
Old Mar 13, 2022 | 11:21 AM
vette4fl's Avatar
vette4fl
Originally Posted by Adice00
Since you seem experienced i wanna ask ya do you think its worth lowering the cradle and getting the rack all the way out, or just moving the rack to the passenger side out of the way and not dropping the cradle?
Old Mar 13, 2022 | 12:47 PM
Adice00's Avatar
Adice00
Navigator
Originally Posted by feeder82
I did mine without dropping the cradle. Work the rack up the pass side and drop it out the drivers side. I had the entire radiator fan assembly out in one piece.
yeah thats the plan how did you support it while it was hanging out the side?
Old Mar 13, 2022 | 12:49 PM
feeder82's Avatar
feeder82
It was completely disconnected, and set on the ground. I did this as apart of a H/C job
Old Mar 13, 2022 | 12:56 PM
Adice00's Avatar
Adice00
Navigator
ohhhh you got the rack all the way out without dropping cradle gotcha gotcha i've heard people just move it out of the way
Old Mar 13, 2022 | 01:50 PM
pjdbm's Avatar
pjdbm
I slid mine out the passenger side and let it hang
Be sure to buy two orings for the power steering lines that you will remove.
Old Mar 13, 2022 | 11:45 PM
rwcantrell's Avatar
rwcantrell
Careful with seal puller. There's an aluminum lip that is part of the timing cover behind the seal you can latch onto and take a chunk out of. If you do, probably ok. Mine has been for a year and a several hundred miles. Yeah need to drive it more!
I wonder if you could take anything off ahead of time? AC belt comes to mind. It's not much but every little thing might help. Pre-loosen stuff as much as possible so you know it's not frozen up? Unplug any electrical stuff ahead of time that's not needed to get to lift. Those connectors are my kryptonite sometimes.
Old Mar 14, 2022 | 01:47 AM
vette4fl's Avatar
vette4fl
One thing I see a lot is guys working on filthy engines. Some simple green and reaching around a bit with a parts brush, followed by a rinse makes life a little nicer.
Old Mar 14, 2022 | 08:16 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Keeps stuff from accidentally falling into the engine, too!
Old Mar 15, 2022 | 12:57 AM
Bruss's Avatar
Bruss
Your doing the job on an Air Force base and they will not allow you to store it overnight? Its been my experience in the Army all of our on post shops allow you to keep your vehicle overnight for a $20 ish fee. Are you able to find another military base nearby? Then you will not be rushed, clean as you go, and enjoy the time with your dad.
Old Jun 20, 2022 | 12:49 PM
fkhachi's Avatar
fkhachi
3rd Gear
Vette4fl,
Thank you so much for sharing this great info.
Have a great day man
Franklin
Old Jun 20, 2022 | 02:35 PM
vette4fl's Avatar
vette4fl
Originally Posted by Gordy M
I have done several, myself and some friends. The more you have worked on the easier it is. My last one took about 4 hours and by then I knew what I should be doing and my helper should be doing. Along the way I found an 30 to one reducer tool from HF that was used on truck times. I wedged that into the frame (took some doing) and the balance and used a 1/2 wrench to remove the bolt and put the new bolt on the last car was for an SCCA autocrosser so we had to use the Stock HB, so we torqued it to 37 ft-lb and then used an angle guage to the 240 degree. Took turns turning the bolt--takes forever--but was easy to do. Unfortunately I did not take pictures of the 30-to-1 tool I had wedged in.
I know this s an older thread, but some may still be subscribed
I did not find a 30-1 multiplier, but did find a 3-1. Perhaps that’s what you had…
https://www.northerntool.com/shop/to...3947_200623947
Old Jun 22, 2022 | 11:42 AM
hellbent1's Avatar
hellbent1
You should definitely have this or something similar if you have a manual trans.
https://www.summitracing.com/parts/s...RoCMh0QAvD_BwE
