View Poll Results: Should i do it
Yes you'll finish it in time
70.00%
No its impossible
30.00%
Voters: 10. You may not vote on this poll
Harmonic balancer need advice!
Old Mar 10, 2022 | 10:33 PM
Adice00's Avatar
Adice00
Navigator
Default Harmonic balancer need advice!
So i have a wobble and a loud chirp from the balancer and i know the problem's you can have if it gets worse so i ordered all the necessary parts (summit HB) to do the job. However im a jet engine mechanic in an air force base and we have lifts that are available to rent but we can only use them for 7 hours at a time and i obviously am handy with a wrench being a jet engine mechanic but i dont know if its fesable for me to have it all put back together in about 6.5 hours. The car has to be off the lift and drive away in 7 and ill be totally screwed if i dont have the steering rack and **** back in. Should i try?
Old Mar 11, 2022 | 12:56 AM
ThomasR's Avatar
ThomasR
That's some good write-ups and YouTube videos out there. Study all the steps, make sure you have everything, and have a friend help. I say do it.
Old Mar 11, 2022 | 01:07 AM
Adice00's Avatar
Adice00
Navigator
thanks i have studied all the videos i think i have the steps down by heart. And my father whose a good mechanic will be assisting. If i go for ill post how it goes haha
Old Mar 11, 2022 | 01:31 AM
Eshoremd's Avatar
Eshoremd
2023 C5 of the Year Finalist - Modified
What happens if you can’t finish it?
Old Mar 11, 2022 | 01:37 AM
Adice00's Avatar
Adice00
Navigator
Expensive fees, can't use the lifts anymore, car will sit outside until i figure out what to do probably get rust on internals while taken apart, not good
Old Mar 11, 2022 | 07:42 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I did the job by myself, and was in no rush, but it took close to 20-22 hours. However, I also came down with a bad case of "while I'm in there", and pulled the timing cover and replaced the timing chain, as well as pinning the crank. That certainly added 4-5 hours to the job.
Old Mar 11, 2022 | 10:10 PM
rrwirsi's Avatar
rrwirsi
My go to Vette mechanic charged 6 hours labor to do the HB change.
Old Mar 12, 2022 | 12:47 AM
Bruss's Avatar
Bruss
I usually run into unforeseen problems when I work on my cars. Murphy's law. Maybe your experiences are different. I would not bet on it going smoothly. That's just me though.
Old Mar 12, 2022 | 03:45 AM
vette4fl's Avatar
vette4fl
Have good quality puller and installer tools. If you’re changing the front seal, you’ll need a seal alignment tool.
Summit: Installer - SUM-900135
Amazon or Summit: Puller - OEM Tools 25090
Amazon: Alignment Tool - SacCityCorvette LS Timing Cover Alignment Tool and Seal Installer.
You’ll need an 18mm line wrench for the steering rack lines.
Summit Racing has a tool that mounts to the balancer to prevent the engine from turning when removing or installing the balancer. Summit: SUM-906008 Balancer Wrench
Have all parts and specialty tools in hand before making a schedule. I just had to wait a month for my Dayco balancer from Summit…
Old Mar 12, 2022 | 03:50 AM
Adice00's Avatar
Adice00
Navigator
thank you for the heads up, i have the front main seal, the summit balancer, the LS balancer installer tool, a flywheel lock out tool, arp bolt, belts, and new tensioners, MAP gas torch, and the necessary torque wrenches and yeah the line wrench. I dont thinking missing anything vital👌
Old Mar 12, 2022 | 03:53 AM
vette4fl's Avatar
vette4fl
Dont forget to secure you’re steering wheel too 👍
Old Mar 12, 2022 | 03:57 AM
Adice00's Avatar
Adice00
Navigator
ah yes i have a rope and bungees and a pole ill see what works best
Old Mar 12, 2022 | 05:16 AM
YYT's Avatar
YYT
Cruising
A cheap seal puller will make a easy job removing the old seal.
Old Mar 12, 2022 | 05:25 AM
Adice00's Avatar
Adice00
Navigator
they have one for rent at the base auto shop i checked it out it should suffice 👍
Old Mar 12, 2022 | 05:27 AM
Eshoremd's Avatar
Eshoremd
I say go for it! You seem to have everything you need and good help.
Take your time and don't panic like me.
Old Mar 12, 2022 | 10:43 AM
tabbruzz's Avatar
tabbruzz
I've done one on my 99 and now doing another on my 01. The 99 was done with a friend and it took more then 7 hours overall I believe but we took our time and did not have All the tools....Thus time I plan to do it myself but do have all the tools and parts ready to go...since I did it once already it should go alot quicker....if I were you I would probably shoot all the bolts with pentrating oil the day before just incase some are rusted on a bit....I think you can do it with two people under 7 hours but just keep moving to get it done....
Old Mar 13, 2022 | 09:58 AM
Gordy M's Avatar
Gordy M
I have done several, myself and some friends. The more you have worked on the easier it is. My last one took about 4 hours and by then I knew what I should be doing and my helper should be doing. Along the way I found an 30 to one reducer tool from HF that was used on truck times. I wedged that into the frame (took some doing) and the balance and used a 1/2 wrench to remove the bolt and put the new bolt on the last car was for an SCCA autocrosser so we had to use the Stock HB, so we torqued it to 37 ft-lb and then used an angle guage to the 240 degree. Took turns turning the bolt--takes forever--but was easy to do. Unfortunately I did not take pictures of the 30-to-1 tool I had wedged in.
To Harmonic balancer need advice!
Old Mar 13, 2022 | 10:04 AM
Adice00's Avatar
Adice00
Navigator
Since you seem experienced i wanna ask ya do you think its worth lowering the cradle and getting the rack all the way out, or just moving the rack to the passenger side out of the way and not dropping the cradle?
Old Mar 13, 2022 | 10:19 AM
leadfoot4's Avatar
leadfoot4
Sure you want to phrase it like that? The OP has only a 7 hour window of opportunity......
Old Mar 13, 2022 | 11:20 AM
pjdbm's Avatar
pjdbm
I did this in about 8-10 hours by myself on my back.
I would not want to be "under the gun" when working on a car, especially the vette.
What happens if you really want to clean & detail an area while its all apart but pressed for time?
Maybe work like this on a customers or friends car but not your own.
JMO
