Installed CLB security code???
Old Mar 22, 2022 | 04:42 PM
SemiRetired's Avatar
SemiRetired
5th Gear
Default Installed CLB security code???
Hi everyone.
Have a 2004 Convertable, just bought it 2 weeks ago…. Car is running fine. I installed the CLB bypass for the 3mph shut off. Car does start fine. The problem I am having is the security light stays on all time now.
hoe do I correct this or is this normal??
thanks for everyone help!
Dale
FT Pierce,FL
Old Mar 22, 2022 | 08:07 PM
Alley Oop's Avatar
Alley Oop
I installed the module from Compliance Parts, no problems with a security light. If Compliance Parts made your unit, I would email them.
Old Mar 23, 2022 | 02:46 PM
rrwirsi's Avatar
rrwirsi
Agree. The only fix that assures your will not have this issue is from......................
complianceparts.com.
If already installed, call "Richard". He is #1 in customer service
If not installed and you buy one, make sure you do the brown wire connection that is optional but, IMHO, necessary.
Old Mar 24, 2022 | 08:26 AM
ztheusa's Avatar
ztheusa
Veteran: National Guard
I wonder if your car has ever had the dealer recall fix? That caused more problems than it ever fixed.
The LMC5 is fine, but there are SO many threads that it causes problems and you have to call "Richard."
The CLB usually works unless the factory recall has been done.
To Installed CLB security code???
