Radio issues
Old Apr 1, 2022 | 04:19 AM
gmagahis's Avatar
gmagahis
6th Gear
Default Radio issues
Did anyone else have issues with aftermarket radios and the music portion cutting off during any hard accelerations and last gear accelerations right after it switches to that gear? I can reset it by turning the radio on and off, but it'll be still susceptible to the same problem. I avoid any hard accelerations to try to mitigate the issue, but I can only do so much for the other action.
I have a Kenwood 7" model DMX7706S. I tried to do some research and possibly a voltage regulator may fix the problem. I also have a feeling the radio may also be what is causing a parasitic drain on my car. Any advice would be helpful!
