Headlight Issue
Old Apr 5, 2022 | 10:09 PM
DaveClark's Avatar
DaveClark
4th Gear
Default Headlight Issue
My C5 passenger headlight will not rise. I thought it might be a motor issue and the other day I was driving and got caught in a light rain and the headlight started working fine. So I'm thinking it might be a ground problem. Any suggestions or has someone experienced this problem?
Old Apr 5, 2022 | 10:13 PM
rrwirsi's Avatar
rrwirsi
My passenger headlight did the same routine for months until it finally just stopped opening. I replaced the motor and all is fine.
Old Apr 5, 2022 | 10:22 PM
STRMLNE's Avatar
STRMLNE
turn the motor manually on the back counterclockwise one quarter turn or even an 1/8th of a turn. See if it works. I bet it will.
Old Apr 6, 2022 | 09:16 PM
DaveClark's Avatar
DaveClark
4th Gear
Thank you for the tip about manually adjusting my headlight a quarter turn. It actually fixed the problem, I don't know why or how but it did. Tonight I converted the car over to LED lightning, everything went well but I am pondering if I can use dual sided tape and mount the headlight high beam and low beam resistors to the frame. Any thought on that?
Thanks Again
Old Apr 6, 2022 | 09:21 PM
STRMLNE's Avatar
STRMLNE
Thanks Again
I knew it would. It’s a secret trick. I think the forum should make me a tech moderator! 😂😂 Glad it’s all fixed !!
Old May 25, 2022 | 07:53 PM
Joegibson's Avatar
Joegibson
6th Gear
Default Same problem with my c5
When I turn the headlight opener it works for a while but it is not a fix.I just had ebcm repaired and now I have this problem will it always be something. My car is a 2002 with 49000 miles
Old May 25, 2022 | 10:54 PM
The Former's Avatar
The Former
Banned Scam/Spammer
Your car is junk. I'll be by to pick it up. I'll have a check for 5k with me. Final offer! Just kidding of course. Sometimes these rigs get you down. They're right on the knife's edge of old/new. Old enough to be shitty. New enough to be really cool. You can fix them yourself which is awesome imo. Yet, they are advanced enough to be hanging with the tough guys!
Right now mine is doing the old ac shuffle. The doors are trying to reset in the dash. I can hear them. It's a constant. I know how to fix this (fuse pull and put back) but haven't done it yet. It's always something! That's the fun of it.
I've blown up my share of engines in my time. THAT'S a true bummer. But if yer not breakin' anything, yer not pushing it hard enough! Good luck!
Old May 26, 2022 | 11:25 AM
Moved to C5 Tech.
To Headlight Issue
