Clutch
Old May 3, 2022 | 08:57 AM
Joe Scafide's Avatar
Joe Scafide
Default Clutch
Average price to swap out clutch i need a new bearing but since its apart i want it all changed
Old May 3, 2022 | 10:33 AM
jdmvette's Avatar
jdmvette
Night Owl for life
~1k (parts+tools) if you DIY like I did.
I'd guess x2-3 if you have someone do it for you
Old May 3, 2022 | 10:45 AM
chilnviln's Avatar
chilnviln
aboot $3000 if a shop is doing the work, and roughly $1000 if you're doing the work. I don't know in Chicago but I was getting quotes of $3K-$3500 in California and I've heard others getting quotes around $2500 out the door. shop around
Old May 3, 2022 | 11:50 AM
LowcountryVette's Avatar
LowcountryVette
I got a quote not too long ago. Labor was around $1800. Total was around $3k for replacing just about everything but the rear main
Old May 3, 2022 | 04:19 PM
STRMLNE's Avatar
STRMLNE
This depends on a ton of variables mainly what clutch you choose. Big difference in cost between a monster triple and an oem luk.
However, the oem clutch is $275, slave $150.
Average labor for a shop is $1500.
About additional $750 to rebuild the torque tube (bearings and couplings).
Old May 5, 2022 | 06:33 PM
Joe Scafide
Default Thanks
You guys are in the ballpark chevy dealer $2600
Old Jun 5, 2022 | 08:42 AM
Joe Scafide
Default clutch
car is all done it was the piolet bearing but since its apart i had every thing done all new stock parts $1850 out the door what makes piolet bearing go out?
Old Jun 5, 2022 | 12:47 PM
helga203's Avatar
helga203
Miles or bad luck and doing 8k rpms neutral drops or clutch launches.
Old Jun 6, 2022 | 07:59 AM
Joe Scafide
Default Clutch
I think staying off the drag strip will make clutch last longer but wtf its fun and safe
To Clutch
