Front headlight
Old Jun 17, 2022 | 09:52 PM
Bond007's Avatar
Bond007
Default Front headlight
I went to turn on my headlights on my 2001, but only one comes up
any HELP would be appreciated.
Thank You
Cheers
Old Jun 18, 2022 | 04:42 PM
rrwirsi's Avatar
rrwirsi
When you turn the headlights on, does the one that does not come up make a grinding sound. If yes, probably need replacing. If no, check the connector between the headlight control module and the headlight motor. Take the connection apart making sure it is free of corrosion and the connections are solid between female and male.
Old Jun 21, 2022 | 06:50 PM
wydopnthrtl's Avatar
wydopnthrtl
There is a gear upgrade kit. If its mechanical check into doing that
Old Jun 22, 2022 | 12:16 AM
jim993's Avatar
jim993
If it grinds, you need to replace the gears. I used two kits to upgrade both headlights from Rodney Dickman about ten years ago, still good.
http://rodneydickman.com/index.php
If it does not make a grinding sound, it could be the bumpers that provide a soft stop when the headlight is going up or down.
Check the following thread-
https://www.corvetteforum.com/forums...-stays-up.html
To Front headlight
