Help TTS owners!!
Old Jan 3, 2003 | 09:07 PM
Dugmole's Avatar
Dugmole
St. Jude Donor '12-'13-'14-'15-'16
Default Help TTS owners!!
Ok, installed the TTS headers on a Z06. The headers made contact on the passenger side aluminum cross arm. According to TTS and LAPD remove material until it stops. I have 1/4" clear, and it still makes contact on slight left turn. I have posted before and David F suggested tighter motor mounts.
The mounts look great, but $295.00 more and ? Anybody else had these same problems? I am ready to pull these things off and S--Can them :U
Old Jan 4, 2003 | 12:50 AM
DsC5's Avatar
DsC5
Default Re: Help TTS owners!! (Dugmole)
I think MattG at Exit 28 has TTS headers - he should be able to help you. :seeya
Old Jan 4, 2003 | 03:47 AM
Austrian Vette's Avatar
Austrian Vette
Sorry to hear that.
I never had such a problem with the TTS`s.
Michael
Old Jan 4, 2003 | 08:41 AM
99HRDTP's Avatar
99HRDTP
No problems c the TTS here. Give it a little more time - I think they're good equipment. As suggested, maybe MattG can be of some help when he spies this post. Good luck, man. :chevy
Old Jan 4, 2003 | 11:37 AM
MattG's Avatar
MattG
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
Default Re: Help TTS owners!! (99HRDTP)
Hmmm I have never heard of such a problem with TTS headers.. You say you got them from LAPD, are you sure they are not TPIS headers? I have just seen quite a few people get some of these acronyms mixed up, TTS, TPIS, etc..
I am not sure what to tell you other than maybe return the one that is rubbing and get another one.. It sounds like there may be a manufacturing defect or one of the tubes are bent wrong, etc.
Old Jan 4, 2003 | 02:36 PM
wickedvette's Avatar
wickedvette
Cruise-In II Veteran
Cruise-In III Veteran
I barely clear the aluminum cross member on the passenger side with my TTS long tubes. I have checked it from time to time and it seems to be OK. It appears that it may barely touch under hard acceleration.
Old Jan 4, 2003 | 02:48 PM
johnnyC5's Avatar
johnnyC5
no problems here either....
i never really heard of this happening with TTS
did u end up getting the Install Instructions (Word DOC file)? maybe they would help somwhat. They are great instruction supplied by Exit28 and I believe originally put together by a forum member, 4 pages long!!!
If you dont, i can send it to you, just email me if you like.
hope everything works out for you
Old Jan 4, 2003 | 09:25 PM
YELLOWDREAMZ's Avatar
YELLOWDREAMZ
I installed the TTS headers when they first came out. They are really close on the passenger side. About 1/8" gap. I took a dremel tool and cut some of the aluminum away to gain a little more clearance.
Old Jan 4, 2003 | 10:50 PM
Dugmole's Avatar
Dugmole
Default Re: Help TTS owners!! (YELLOWDREAMZ)
I did the same. Removed about 1/4" from the aluminum A frame. Still hits on left turn under acceleration. Im going to take a little more off and that's it.
I like the headers but still need the rest to make it work :lol:
Old Jan 6, 2003 | 10:20 AM
ToplessTexan's Avatar
ToplessTexan
Ditto on clearancing the passenger side header. I'm not aware of anybody that resolved it using a torque strap or solid mount.
There's an interesting motor mount thread or two at LS1Tech.com but I'm not sure how applicable it is to C5s. It caught my attention as I've been thinking about solid mounts for a while.
Old Jan 6, 2003 | 10:24 AM
kromberg's Avatar
kromberg
Default Re: Help TTS owners!! (ToplessTexan)
I have not had any problems with my TTS headers other than it is impossible to buy extra colletor/reducer flanges from them.
Why will they not sell them seperately? Have they not heard of people wanting to run turn downs at the track :(
Keith
To Help TTS owners!!
