VaraRam Installed, my thoughts...
He set all sorts of state track records.. was it RAM AIR or was it the shoes? Guess well never know.. :p: :hat :troll :p: :hat :troll :p: :hat :troll
The car was dyno'd with the hood open and thus could pull cold air from outside. Mys supicion is this is why Vararam cars run better in the 1/8 mile. After that the cool air coming in the vents has displaced any hoy ait, and ther eare no more gains. I have considered testing this by simply making some ducting to conenct to the stock box, and then running them down to the factory grills. Another idea I had was to simply make an isolator or partition to separate the airbox area from the rest of the engine compartment.
One of the things that may be helping me, is that I keep my hood open until right before I make my pass, so the air doesn't have a lot of time to heat up or stagnate under the hood.
David Plum - There is a bit of difference in a Pro Stock motor and a Vararam. I am not saying that Ram-Air doesn't exist at all. It is simply in the application we are discussing unless you are over 150mph you will not see "Ram-Air".
Now as for 4th order harmonic waves in sheet metal manifold that is a whole different story. Yes, using the reversion waves in the intake you can tune a motor to make 110-115% efficency in a small window. That is a lot different. Plus, I wonder what the airspeed in the manifold is at 8500rpm...
[Modified by J-Rod, 11:34 AM 1/6/2003]
here are my before and after dynos, on the same dyno rollers with the same operator at MTI.
09/02 tie-wrapped k&n, S2 TB, magna flow x/stock cats
01/03 vararam, S2 TB, magna flow x/stock cats
Quin, I wish you'd get all your facts straight before using my car as an example. I can only comment on what my car has done. I'm not sure why you want to use my car as a comparison when it was clearly lower than J-rods car to begin with (as evidenced by my 09/02 dyno where I DID have a tie-wrapped filter like J-rod). Who's to say J-Rods car wouldn't dyno even HIGHER with a vararam?? Has he tried one? I don't think so.
J-Rod : 356, 359, 372
BLU-BY-U :352, 360, 373
sorry if I pissed ya off.....certainly didn't mean to
:cheers:
Let's not forget that the perfect filter setup for dyno numbers is an open airbox with lots of filter area that can easily feed the engine. The VR does not show up well on a dyno becuase the area in the runners is not compressed when standing still and the inlet charge has to be pulled from a greater distance.
:steering:
RG
But at 115 mph trap speeds, you aren't achieving ram air through some twisty plastic tubes with VENTS to let "water" out.
Carroll Smith in "Tune to Win", P. 106.... (most of his experience comes from INDY racing, good book..)
Intake Ram (psi) =
Air density (lb/ft^3) X (Air velocity in FPS)^2
288g
80 mph:
.076 X (118)^2
---------------- = 0.11 lb/in^2 (psi)
288 X 32.2
BUT he goes on and says:
"In both cases we have assumed a 100% efficient duct, which is not possible---75% efficient would be a good one"
0.11 psi x .75 = 0.08 psi.
Turbulence isn't the real problem. In any piping run, a boundary layer builds up next to the wall where the flow velocity is actually zero. As the roughness of the pipe wall gets worse, the boundary layer grows thicker. As the air moves on down the pipe, it is slowed by the boundary layer effect (head loss) and the boundary layer essentially grows thicker slowing the air more. If the run is long enough, the head losses can actually be long enough to completely stop the flow (pressure differential between the inlet and outlet is zero).
Take the vent on your dryer and add about 30 feet to it and you'll see that there's not enough pumping power (from the exhaust fan) to even move the air through the hose. The same head losses occur every time straight flow is interupted by a bend, valve, fitting, etc.
There's a piping engineer's bible published by Crane Valves (Technical Paper #410) that puts all the equations together and will let you calculated the pressure drop through a piping network with all the variables you could think of.
Ain't math fun?:)
All you guys getting great results.... just keep on keepin' on.:)
RG
[Modified by RG in Dallas, 12:28 PM 1/7/2003]
You have a vested interest in the product.
As I have said in other posts, I believe there are probably some gains to be had from Cold Air Induction, a combination of cooler, denser air providing more oxygen to the engine AND the better PCM values you get from that cooler air.
This argument is about ram air, and since no one wants to put a manometer in their vararam box, we don't have any evidence of ram-air or boost except vararams advertising claims.
I didn't start this one. I'm just backing J-Rod's post up with the "math/physics" that explain what he said in more detail.
Phillip :cuss
Phillip :cuss
RG
It's all good, Tom...if one wants a Vortex, we sell those, if one wants Blackwing, we sell those, if ones wants to stay stock, we carry those too.;):):D
RG
RG
