VaraRam Installed, my thoughts...
Old Jan 7, 2003 | 05:10 PM
  #41
Tom Steele's Avatar
Tom Steele
Default Re: VaraRam Installed, my thoughts... (Phil97SVT)
If you have some type of empirical data that states that the product doesn't work then post it. Otherwise keep biased opinions that have no background off of the board. This crap of bashing products is getting old.
Perhaps you shoud re-read my posts - you apparently didn't comprehend them correctly.
I CLEARLY stated that it is possible that the vararam may introduce cooler air into the engine and that may create a doubly helpful effect by putting denser air into the engine and improving the PCM's settings because of the cooler air.
My intial comments are clearly aimed at the ram-air myth.
Old Jan 7, 2003 | 05:12 PM
  #42
RG in Dallas's Avatar
RG in Dallas
Elite Member
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: VaraRam Installed, my thoughts... (racer44)
It works Phil, you know it, I know it, and many others know it.:)
RG
Yep, Just like the other major brands work too! No one better than the other. :cheers:
...and maybe one day you'll get one and try it out and see that it makes you faster.:) vrrroooommmmmmmmmmm, vrrrrrroooooommmmmmmmm!!!:):D
RG
Old Jan 7, 2003 | 05:33 PM
  #43
Racer's Avatar
St. Jude Donor '11
Default Re: VaraRam Installed, my thoughts... (RG in Dallas)
RG
..or slower :p: put...put..put..put put..plop. :crazy: :D
Old Jan 7, 2003 | 05:53 PM
  #44
RG in Dallas
Elite Member
Cruise-In I Veteran
RG
Slower is for the guys you try and steer from the VR's greatness and benefit...a FASTER car...there you go...you can have the last word...lol... I know you want it.:cheers::D:)
:cool:
RG
[Modified by RG in Dallas, 4:55 PM 1/7/2003]
Old Jan 7, 2003 | 06:08 PM
  #45
Racer's Avatar
St. Jude Donor '11
Ok RG, my last word is, (for now) if you got paid on hype alone, you could retire today! :lol: :cheers: :p:
Old Jan 7, 2003 | 06:20 PM
  #46
RG in Dallas
Elite Member
Cruise-In I Veteran
The VR works...you know it...:) No hype needed...just info on the boards we pay to advertise on. You choose to come on just about every VR thread to 'help' others decide on what they should buy for an intake by touting your own brand and all that comes with it like the rolleyes smiliey.... You aren't the first and won't be the last that does that to a particular intake. I choose to show what we offer to sell that works, simple. We pay for that right, and you have that posting right. I guess we'll see each other again.:)
No need to take shots either, Tony, though I've come to expect that here and elsewhere. Oh well, it's all good..you take care. Have fun and if you need anything, call or write.:cheers: Hype may be what sold you on your intake, I don't know, but, we have many happy customers to vouch for the VR and the Vortex and the Blackwing. We'll be ok.: and so will you.
RG
[Modified by RG in Dallas, 5:23 PM 1/7/2003]
Old Jan 7, 2003 | 06:38 PM
  #47
Racer's Avatar
St. Jude Donor '11
Now RG, I thought you said I got the last word?? Hmmmmm. :skep: :cheers:
**EDIT** I spelled thought wrong so I corrected it. Also, I never, ever said the VR doesn't work. It appears to work as good as the other brands, I have seen some with better results, some with worse. I was going to say they all work better than the stock box, but I don't really know if we can say that anymore, thanks to JRODS dyno numbers. :cheers:
[Modified by racer44, 4:42 PM 1/7/2003]
Old Jan 7, 2003 | 10:42 PM
  #48
chuckster's Avatar
chuckster
WHO CARES! This topic has been beaten to death and it gives me a headache reading this crap. Bottom line: If you dont believe in the product DONT BUY IT! I have had the vararam for roughly 6 weeks now and I am very happy with it. The car has shown a lower IAT temp(compared to the K & N) from the first test drive and a quicker pop off of of a roll. If you have some type of empiracle data that states that the product doesn't work than post it. Otherwise keep biased opinions that have no background off of the board. This crap of bashing products is getting old.
Phillip :cuss
:iagree:
I need to get one. I know it works.
The funny thing about the Vararam is Everyone who has one says they have had "MEASUREABLE" gains at the track..
All the naysayer can sho you all the math in the world as to why it is NOT ram Air.. BUT, not a single one of these College Professors can give a single Real reason for why people are seeing gains over other COLD air intakes.
I firmly believe there is no RAM Air (as defined) but most people forget about the benefit of Positive Air Pressure to maintain the flow of air all the way to the back and far reaches of the intake manifold.
Most cold air intakes just tap "across" the air flow.. This causes turbulence (like blowing air across a coke bottle opening" In fact, if you blow the air across that same bottle fast enough and at the right angle, you can actually cause a vacuum and ultimately suck the contents right out. That is Physics... ;)
The Vararam may not provide True RAM AIR but it does provide the MOST Positive (non mechanical) pressure you could ever attain in your intake. And it Obviously Works...
[Modified by chuckster, 10:44 PM 1/7/2003]
Old Jan 8, 2003 | 01:29 AM
  #49
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Default Re: VaraRam Installed, my thoughts... (Tom Steele)
Old Jan 8, 2003 | 09:32 AM
  #50
Phil97SVT's Avatar
Phil97SVT
Default Re: VaraRam Installed, my thoughts... (chuckster)
Honestly I think a couple of the reasons that the Vararam works....
1) Filter flows more CFM than a gauze type
2) headunit has a radiused inlet to the MAS.....it has been proven that a radiused inlet helps reduce turbulence while flowing cylinder heads
3) It drops the air intake temps....drawing from the nose of the car will also see radiant heat from the radiator.
Phillip :seeya
Old Jan 9, 2003 | 06:26 PM
  #51
Tom Steele's Avatar
Tom Steele
Default Re: VaraRam Installed, my thoughts... (rbartick)
We are very funny!
Old Jan 9, 2003 | 07:50 PM
  #52
RussBt's Avatar
RussBt
Scan some of your time slips and post them. Until then..
Old Jan 9, 2003 | 07:54 PM
  #53
David Plum's Avatar
David Plum
Tom stick with radio
Old Jan 9, 2003 | 09:34 PM
  #54
Racer's Avatar
St. Jude Donor '11
We are very funny!
Ok, I will play along :D
Old Jan 9, 2003 | 09:44 PM
  #55
bparker's Avatar
bparker
:lol:
We are very funny!
Old Jan 9, 2003 | 09:51 PM
  #56
Racer's Avatar
St. Jude Donor '11
Default Re: VaraRam Installed, my thoughts... (bparker)
:lol:
We are very funny!
Ok, I got one more and then I am out! :D
Old Jan 9, 2003 | 09:58 PM
  #57
bparker's Avatar
bparker
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :seeya
:lol:
We are very funny!
Old Jan 9, 2003 | 11:01 PM
  #58
RussBt's Avatar
RussBt
:rofl:
Old Jan 10, 2003 | 06:17 PM
  #59
Tom Steele's Avatar
Tom Steele
Default Re: VaraRam Installed, my thoughts... (David Plum)
As opposed to?
