Oil issues and replacement estimate
Old Jul 8, 2022 | 12:40 PM
grinder11's Avatar
grinder11
Originally Posted by C5MSG2004Vert
I would check if the oil pressure sensor is leaking since it can leak onto the valley pan. $1000 for the valley pan gasket. That's really expensive. The gaskets are like $30 and couple of hours of labor.
I agree!! Pulling the LS1/LS6 intake (to access the valley cover/gasket) is super easy. OP-Disconnect the positive battery terminal. Spend $10 bucks, get a fuel line disconnect tool. Remove the plastic coil covers, disconnect fuel line. Unplug the coil packs, 1 each side. Loosen 10 M6 hex head cap screws that hold the intake to the heads, with a 10mm socket. Unplug the throttle body. Disconnect the MAP sensor and vacuum line at the rear of the intake. There may be a couple more easy to remove things that I've forgotten. Lift intake out and place on a nice clean bench or whatever you have thats CLEAN. Plug the 8 intake ports on the heads with a couple of paper towels in each, or use duct tape to seal them. Remove valley cover and gasket. Replace gasket, and reinstall everything in reverse of removal procedure. As for new wiring plug-ins, and new sensors, I call BS if you have no codes. My engine had an oil leak for over 3 years. Never replaced any wiring or sensors. If no codes, no replacements are necessary. You must look like a cash cow to whoever wrote up this repair estimate!!!!
Old Jul 8, 2022 | 03:10 PM
lspowah's Avatar
lspowah
Originally Posted by Gordy M
To bad you do not have your location in your avatar, many times a close by member is more than willing to help. Your problems are not the first we have ever seen and often there are several different solutions to solve your problem. Normally the front oil seal does not leak unless the balancer has been replaced and who ever did the job did not do the seal at that time. There was a recent article about a product that helps expand old seals and stops or controls oil leaks, etc.
I’ve been meaning to fill that out thank you for the reminder!
Old Jul 8, 2022 | 03:11 PM
lspowah's Avatar
lspowah
thank you for the tips man. I will look up how to do it and yes I believe you’re right. I was in my work clothes so I was dressed decently I guess. Idk. Getting second diagnosis now I will be sure to post it. Should be getting another from a friend of a corvette group member at his shop Wednesday
Old Jul 8, 2022 | 03:14 PM
lspowah's Avatar
lspowah
Originally Posted by Purple92
lspowah - Look - your car is leaking a little oil. OK - not great, but hardly the end of the world. If the leakage is really slow as you seem to be seeing, live with it for a while. A quart of oil runs less than $10.
I'm betting that $4,800 estimate came from a dealership. If I were you - I'd look for an Independent place that works on Vettes regularly. They should be substantially less expensive. You don't need special factory tools for the work being shown on the invoice. I haven't done the jobs listed on a C5, but $3,000 in labor to deal with some oil leaks is pretty hard to swallow. Look elsewhere.
And don't beat yourself up - I would not consider oil leakage to be that big an issue with a used car. I'd be much more concerned with other stuff.
thank you for the help. This was actually at an independent shop. Getting 2nd estimate now I’ll be sure to post it too
Old Jul 8, 2022 | 03:27 PM
lspowah's Avatar
lspowah
Took to another shop. They show no leaking at all other than at the plug itself as I had initially suspected. I’ll start with that and hope it works. $120. Getting another opinion on Wednesday. Strange to find such distanced diagnoses
Old Jul 8, 2022 | 05:39 PM
lspowah's Avatar
lspowah
Originally Posted by JCMDoug
1st thing I do to fix a leak is use a rag and call it good unless its more than a slow drip or seep.
The seal of the harmonic balancer could be leaking and running down making it look like the oil pan.
The PVC system could have a problem and if it is fixed the leaks could stop.
I have one person that I sort of trust to work on my cars and I only sort of trust him. They take me into the shop and show me the problem and ask are you going to fix it or us.
If you can get a good set of ramps or low profile jack and start wiping.
thanks for the tip. Went to another shop today they said they didn’t see anything besides the drain plug needing replaced. Getting third opinion from a friends friend who has a shop and a corvette. I’ll keep y’all posted. Awfully strange
Old Jul 8, 2022 | 06:29 PM
jim993's Avatar
jim993
That is GOOD news!
We are all interested to hear more and that is really the only leak.
Old Jul 8, 2022 | 06:40 PM
lspowah's Avatar
lspowah
Originally Posted by jim993
That is GOOD news!
i sure hope so. Only one that made sense to me. Where I come from, people don’t try to milk you for cash. In small town Arkansas folks look out for each other. According to the shop today and one of my buddies here I gotta watch out for people doing that. Especially if I pull up in a vette, no matter the year. Always heard people in cities will try but never actually thought it was really something that happened.
Old Jul 8, 2022 | 07:33 PM
gimp's Avatar
gimp
Drain plug would need to be leaking like a sieve to have oil drop off it as you drive, whip up, and coat so much of the engine that someone _honest_ thinks it's a leak from the front main seal and valley cover gasket. Like, a good solid drip for several years.
Let us know how it looks with a new plug and obviously a new crush washer, and after the engine is cleaned to a reasonable minimum spec.
Old Jul 8, 2022 | 10:37 PM
lspowah's Avatar
lspowah
so I drove it home this evening in a “particular fashion” to get her heated and the oil pumping somewhat. I noticed that there is still an itty-bitty little bit of oil like a pinhead amount coming out the plug still at the very bottom. Installed a new plug (magnetic). Wiped it off. Had my wife rev it a bit while I was watching it and sure enough another little pinhead amount came out right at that spot a few minutes later. The very bottom part of the plug towards the ground where it meets the pan.
I definitely get what you were saying. However the shop today said they didn’t see any leakage from those other areas. I don’t even know what to believe at this point. And after seeing that just a bit is still seeping out of that plug area, it makes me think maybe the lower pan has a burr or has a thread stripped that they didn’t catch. I don’t know why the shop today would say that if it wasn’t true as that would be an opportunity for a big job for them.
didn’t see any leakage coming down around from the top of the bolt, pan gasket, etc.. like I said I’m beginning to think there is a slight connection issue within the threading of the lower pan. Maybe they just re used the crush washer but I don’t know why the hell they would
Old Jul 8, 2022 | 10:52 PM
gimp's Avatar
gimp
That's interesting.
(For what it's worth, I re-use crush washers about 50% of the time with no leaks due to it. Not on purpose, usually due to forgetting to prepare the washer when I do the job and then laziness to get up and find where the heck I put them, and which one of the 4 different kinds is right for the car.)
New plug, torqued to spec, not cross-threaded, goes in nice and easy, no weird feeling? Still seeing a leak? That tells me a thread damage issue can definitely be a culprit. There are multiple remedies. I recommend calling the shop up and having a chat with them about next steps; whatever they propose is likely to be expedient and reasonable.
Old Jul 8, 2022 | 10:55 PM
lspowah's Avatar
lspowah
That's interesting.
thanks buddy. I will holler at them on Monday. I’ve got a feeling it’s such a very slight threading issue that they didn’t even catch it. I’m thinking I might need to replace the lower pan. Maybe some ******* at the dealer I purchased it from torqued it a bit much and it’s just now really surfacing.
I still don’t see how all of those other areas could be seeping oil with the amount I lost over the past few weeks. I mean my dipstick read correctly all the way through. It’s like a drop at a time. Really makes me wonder about that first shop and it hasn’t made sense to me from the beginning
Old Jul 8, 2022 | 10:57 PM
  #33
Rick369's Avatar
Rick369
Who bought and installed the new plug? Is it the correct type? My drain plug has a rubber type ring that is attached to the under side of the head of the plug. Some vehicles use crush washers to seal.
Old Jul 8, 2022 | 11:00 PM
  #34
jim993's Avatar
jim993
Next time you change oil, carefully inspect the pan plug sealing surface for burrs or other discontinuities. Perhaps some careful file or scraper work is indicated. Original C5 drain plugs are sealed with an O ring which is usually very reliable, but an aftermarket plug with a gasket could seep.
On my vehicles with gasketed pan plugs, I always add silicone sealant to the plug before installing. This usually prevents seeps and absolutely prevents a plug you hand tightened but forgot to torque from falling out.
Old Jul 8, 2022 | 11:07 PM
  #35
lspowah's Avatar
lspowah
christian brothers automotive in Austin. They have done work on my truck and have always been fair and did good business. I’m getting a third opinion on Wednesday for sure. The guy took the words out of my mouth when discussing the type of plug, magnetic, gasket on it etc. I don’t know how they would screw up getting the plug
Old Jul 12, 2022 | 06:14 PM
  #36
gimp's Avatar
gimp
Let us know how it goes. Some aftermarket plugs are trash, and it can be hard to get a good source of truth for something as simple as a drain plug.
I use this:
Amazon Amazon
"Dorman 65372 Oil Drain Plug Magnetic M12-1.75, Head Size 15Mm Compatible with Select Models"
It has a rubber gasket/washer under the head, that has never caused an issue for me yet. It also has a magnetic tip to catch any iron/steel grit, both to prevent it circulating and for inspection. With that said, Dorman's products aren't always the best, so I can't guarantee that if you bought this item right now for the stated $5.03 you would be happy for it today, or five years from now.
Old Jul 13, 2022 | 04:48 PM
  #37
lspowah's Avatar
lspowah
I use this: https://www.amazon.com/gp/product/B0011NDZKW/
once again a different answer. Took it to a reputable place today recommended from a fellow corvette member. I walked in and the guy had four Corvettes in his shop along with an old lotus and a heavily modded camaro. He had his zo6 c6 in the shop. That was one bad car.
he verified the crankshaft seal/harmonic balancer are leaking and showed me. He said he didn’t see anything else. Also she needs new tie rods. He’s also going to clean in between the ac compressor and radiator. Roughly $2k for everything. Powerbond race balancer. Tie rod ends.. etc everything
To Oil issues and replacement estimate
Old Jul 14, 2022 | 04:38 PM
  #38
lspowah's Avatar
lspowah
Bump…
Old Jul 14, 2022 | 04:43 PM
  #39
ThomasR's Avatar
ThomasR
That price doesn't sound bad.
Old Jul 14, 2022 | 04:56 PM
  #40
Supercharged111's Avatar
Supercharged111
That price sounds like I need to open a shop!
