Start issue
Old Jul 18, 2022 | 11:30 AM
GmanEd's Avatar
GmanEd
Cruising
Default Start issue
1998 C5
No guage sweep and no start. Have windows radio headlights.
ANy ideas?
Thanks in advance
Old Jul 18, 2022 | 03:39 PM
rrwirsi's Avatar
rrwirsi
Test the battery.
Old Jul 18, 2022 | 04:26 PM
GmanEd's Avatar
GmanEd
Cruising
Battery is good. Out of the blue it started one time. Turned it off and it wont start again.
Old Jul 18, 2022 | 04:49 PM
RWH99Z51's Avatar
RWH99Z51
Have you checked for trouble codes? Any recent work done to it? Has it been sitting a while and just recently started doing this? Rodents? water intrusion? A little more history may help us? My first thought would be a dead cell in a battery also. A load test will show this, a volt meter( unless you know what you're looking for) will not.
Old Jul 18, 2022 | 04:56 PM
GmanEd's Avatar
GmanEd
Cruising
Top leaks a little but there wasnt any water around the fuse box or ECM. It ran fine last Friday we got back from a trip and this morning nothing
It started fine once today. Then it was back to not starting. Nothing done to it other than repalce some burnt out bulbs with LEDS.
Old Jul 19, 2022 | 09:49 AM
mmartinez's Avatar
mmartinez
I belive you have a problem with the Ignition switch contacts or a bad electrical connection. The Ignition switch has contacts that power relays that provide power to the cars different systems, hence you have some power, but not to the part of the car that performs the gauge sweep and such. I am betting the one time it started it did do the normal gauge sweep and indicators turning on and then turning off before starting?
Old Jul 19, 2022 | 11:49 AM
GmanEd's Avatar
GmanEd
Cruising
yeah it did. I am going to put a new stereo in it so while I do that I’ll take a look at the ignition switch
Old Jul 19, 2022 | 08:03 PM
GmanEd's Avatar
GmanEd
Cruising
So today it started up and as soon as a shut the drivers side door it cut off.
Old Jul 20, 2022 | 06:50 AM
GmanEd's Avatar
GmanEd
Cruising
so the carpet under the seat is wet and the footwell is wet. Have the carpet pulled back to dry but will prob remove it and shampoo it. We had a major storm while we were out of town.
tue car started again and ran fine till I cut it off. Then it wouldn’t start again.
I have a new ignition switch coming to put in when I replace the radio so I don’t have to pull the dash apart twice.
just the new developments. Hope I can get it going again.
Old Jul 20, 2022 | 06:58 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
When you open the driver's door you will see a rubber boot between the door and pillar...pull back the boot and inspect for loose connections at the connector there...it sometimes gives go no start conditions !!...you said when you shut the door it cut off.
Old Jul 20, 2022 | 08:30 AM
mmartinez's Avatar
mmartinez
Old Jul 20, 2022 | 05:39 PM
GmanEd's Avatar
GmanEd
Cruising
Got really hot here and evidently dried out whatever got wet. Its starting every time now
Old Jul 20, 2022 | 07:02 PM
mmartinez's Avatar
mmartinez
Not a betting man but I will bet that the BCM probably got wet, that will prevent a car from cranking over and starting, I would let it dry out a couple more days.
Old Jul 23, 2022 | 08:54 AM
GmanEd's Avatar
GmanEd
Cruising
Default Bcm
This is the board
it will start in the evening when it gets hot but this morning nothing
too the board out a let it dry a few days
Think it’s a goner?
Old Jul 23, 2022 | 09:50 AM
mmartinez's Avatar
mmartinez
Is there any visible corrosion on the board? There are several rebuilders of BCM's one them is G7 Computers heard very good things about them. If you buy another BCM you will have to do a relearn procedure, or maybe it will start working. Did you look at the connectors inside the rubber accordion they could be the cause of your cars no crank as well.
Old Jul 23, 2022 | 09:59 AM
GmanEd's Avatar
GmanEd
Cruising
I cleaned it with alcohol and didn’t see any.
where is the accordion you speak of?
sorry new to C5 Vettes Thanks for everyone’s advice
Old Jul 23, 2022 | 01:26 PM
mmartinez's Avatar
mmartinez
The accordion boot is between the door and car, the driver side seems to have this problem because it gets opened and closed more then the passenger side. Loose electrical connections happen in the connectors that contain the female type contacts. This bad connections cause a loss of communication with all of the cars modules which can prevent the car from starting.
To Start issue
Old Jul 23, 2022 | 01:28 PM
GmanEd's Avatar
GmanEd
Cruising
Gotcha. I will look at it this evening. its near 100 degrees here. Thanks so much!
Old Jul 27, 2022 | 04:16 AM
GmanEd's Avatar
GmanEd
Cruising
I think I have found the problem. If it starts and I tap on the bezel around the ignition switch the car will cut off or the gauges will jump.
Old Jul 28, 2022 | 10:14 AM
mmartinez's Avatar
mmartinez
Seems like you have bad ignition switch contacts, there is a write up here on the forum that details how to clean the switch contacts, or simply buy a new ignition switch, be careful there are a lot of made in China switches.
