brake duct clearance
Old Jul 29, 2022 | 06:22 PM
Elektro's Avatar
Elektro
Default brake duct clearance
I want a square set of c5z rear wheels.. 18x10.5, et58. And a 285/35 or 295 Michelin PSS tire (or similar)... nothing crazy. I figure it fits OK on my 1998 based on what I read. (??) But what if I add on the AAF or DRM brake duct kits? Will they clear? Will I lose the turn radius? Willing to add a spacer but I don't want it to poke out the other end.
Old Jul 29, 2022 | 07:59 PM
chilnviln's Avatar
chilnviln
I have a square setup on my Z06, 18 x 11, +55, 295/35 tires and I get a slight rub if I go full lock to lock attempting a u-turn or backing in/out. My car is so low that I try not to do those anyways. I don't know how close a fit these other brake ducts are to stock Z06 ducts but if you're that worried I would cut 1/2" - 1" off the brake ducts before getting spacers for the wheels
Old Jul 29, 2022 | 11:22 PM
Elektro's Avatar
Elektro
Are you rubbing on top because you are lowered or on the inner sidewall because of the tire size? Only a slight rub at full lock is acceptable to me anyway.
Sorry, this kind of backing plate duct, not the little nozzle that barely sticks out of the liner...
https://advancedautofab.com/p/c5-c6-brake-cooling-duct/
The description does say "even works great with large race slicks on the front" but does not say what size a 'large race slick' is.
I sent them an email, see what they say.
Old Jul 30, 2022 | 01:49 AM
ariZona06's Avatar
ariZona06
I've got the Doug Rippie ducts and I get a slight rub at full turn. 315/30/18 square tire setup. If I notice excessive wear during my safety checks I throw on a slab of Gorilla Tape and send it! Track car, minimal street use.
Old Jul 30, 2022 | 07:59 AM
chilnviln's Avatar
chilnviln
Sorry, I mistook those as replacement for missing OEM
Old Aug 8, 2022 | 06:51 PM
Elektro's Avatar
Elektro
Called AAF, he said there will be a very little rub at full lock... if a 3 mm spacer didn't fix it, 5mm would. (or don't steer so hard lol)
To brake duct clearance
