help with codes please
Old Jan 7, 2003 | 03:03 PM
NYtoCA's Avatar
NYtoCA
Default help with codes please
Can somebody tell me what these codes are and what they mean?
P0803
P0103
Thanks!
Frank
Old Jan 7, 2003 | 04:40 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Default Re: help with codes please (NYtoCA)
P0803 is : 1-4 Upshift solenoid control circuit
If you have disconnected your CAGS solenoid, this is probably it. If you have a resistor or bypass plug in place, it may have come loose or somehow not working.
P0103 is: MAF (mass airflow) sensor circuit high frequency.
No idea what could cause that, maybe someone else knows.
:cheers:
Old Jan 7, 2003 | 05:08 PM
NYtoCA's Avatar
NYtoCA
Default Re: help with codes please (Y2Kvert4me)
Thanks for the reply, i have CAGS but like you said maybe it came lose.
Can anybody help on the second code? P0103
Thanks in advance,
Frank
Old Jan 7, 2003 | 05:27 PM
FYNL4's Avatar
FYNL4
P0803 is 1 to 4 Upshift Solenoid Control Ckt
P0103 is MAF Sensor Circuit High Freq
First one sounds like a CAGS problem, maybe some of the other members can help. :thumbs:
Old Jan 7, 2003 | 05:45 PM
NYtoCA's Avatar
NYtoCA
Default Re: help with codes please (FYNL4)
what does P0103 is MAF Sensor Circuit High Freq mean?
Old Jan 7, 2003 | 08:26 PM
FYNL4's Avatar
FYNL4
Sorry, can't help you there. I was hoping another forum member might be able to help.
P.S. You have great taste in cars............
Old Jan 7, 2003 | 10:40 PM
NYtoCA's Avatar
NYtoCA
ttt
Old Jan 8, 2003 | 08:52 AM
yellowvette837's Avatar
yellowvette837
St. Jude 15 Year Donor
St. Jude Donor '03 thru'19
Tampa Events Princess
2015 C6 of Year Finalist
I Believe In The Beer Fairy
I had the codes PO803 and PO801 "Reverse Inhibit". With these codes I would always get PO102 MAF Sensor Circuit Low Freq A" The CAGS was burned so dealer took it off and said that should fix the two codes. (I have the burnt CAGS may see if I can return it???)
Codes again. Dealer took speed shifter out. (Kept it, it is in a box in my garage)
:smash:
Codes again {Finally they traced it to a wiring harness} I have only had the car back since Friday. It took them several trips and several months to finally fix.
Never had the PO102 by it's self. I think in might be triggered by the other codes?? (need to get my speed shifter reinstalled for free, dealer will pay
:boxing
[Modified by yellowvette837, 7:53 AM 1/8/2003]
To help with codes please
