ECBM danger
Old Nov 30, 2022 | 07:57 PM
matt zapp's Avatar
matt zapp
Cruising
Default ECBM danger
My name is Matt and I own a 2000 Corvette Roadster with 5200 miles on the clock. The car is red and is loaded with factory options. My question is this;; I am receiving
a Service Active Handling message on my DIC. This has occurred on several occasions. Does not servicing the ECBM pose any danger in driving the car.
Thanks Matt
Old Nov 30, 2022 | 09:42 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Thanks Matt
Welcome to the Forum !!…see what DTC’s may be set and if you don’t have a scan tool you can access them through the DIC.
Old Dec 1, 2022 | 12:06 AM
vette4fl's Avatar
vette4fl
Here’s some good info on using the DIC. 👍
Old Dec 1, 2022 | 10:12 AM
Moved to C5 Tech.
Old Dec 3, 2022 | 08:06 PM
wrmiles's Avatar
wrmiles
The only danger is the absence of the AH function if you need it. If you get the message, the system has shut itself off.
Old Dec 9, 2022 | 10:31 AM
matt zapp's Avatar
matt zapp
Cruising
Thanks for the help...Matt
Old Dec 10, 2022 | 11:27 AM
grinder11's Avatar
grinder11
Your "Service AH" may have nothing to do with the EBCM. Exactly what codes are you getting? I've had a Service TC, Service AH for years. It's a bad SWPS, which seem to fail far more often that the EBCM. Mine had a C1283 H C, meaning a History code, and a Current code. It would only display this code while using the DIC WHILE THE ENGINE WAS RUNNING!!!! Thanks, Rob (C5 Diag!)!!
Old Dec 12, 2022 | 02:36 PM
johnson-rod's Avatar
johnson-rod
Post the codes. There are a bunch of codes and reasons for that message that have nothing to do with the EBCM. Some are wiring, some are grounds, some are connections and some the pump just needs a workout.
Old Dec 12, 2022 | 04:17 PM
matt zapp's Avatar
matt zapp
Cruising
Hi Rob...the codes that appear are........Service Active Handling.......Service Traction Control.....They appear after 30 minutes of driving., When
I turn the engine off and start it back up the codes disappear...I went through the process of cleaning out the codes but they come back. thanks Matt
Old Dec 12, 2022 | 04:53 PM
C5 Diag's Avatar
C5 Diag
These are not the codes...you access the DTC's through the DIC...they will be a P,C,B, or U folowed by 4 digits...watch the video and report back...you will he H or C after the 4 digit code...history or a current code.
To ECBM danger
