Unable to program key fob
Old Dec 30, 2022 | 06:04 PM
MAC5's Avatar
MAC5
The receiver shown in that picture i attached above is located behind a panel directly above the rear tire hump and behind the rear window support.
2 or 3 panels need to be removed starting from rear panel.
Old Dec 31, 2022 | 10:24 AM
yellow2007's Avatar
yellow2007
I got the tps service message a few days ago. My dic only displayed "xxx". I took a magnet, placed the car into "tire learning" mode and startint at the drivers front tire held the magnet over the tire valve for about 5 seconds until the horn honked. Then went around clockwise for each tire. Now the warning is gone and I get actual tire pressure numbers.
I also did a fob learn yesterday for a 2nd fob I bought. Are you holding the lock/unlock buttons for at least 15 seconds? Tha's how long I held mine down.
Old Feb 1, 2023 | 10:26 AM
goodboyralph's Avatar
goodboyralph
Cruising
I know this is old now, but the issue has been determined. The receiver is bad and needs to be replaced. When the shop finally got to it, it was actually broken off of the harness and just sitting in the bay where it is located. It doesn't have any power to it and a new one was ordered. 2001 they switched to a new receiver, which is more than double the cost of the receiver in the 97-2000 models and much more difficult to find. My shop could only find ONE from any reputable business that he trusts to purchase used parts from.
Should have it in and running within a week or two, and it should also take care of the service tire pressure sensor message that I'm getting, since both the key fob and TPMS readings are related through the same receiver.
Old Feb 25, 2023 | 11:59 AM
goodboyralph
Cruising
Final update....new receiver came in and fixed not only the fey fob issues but also the TPMS sensors not reading. Thanks to all for the help!
Old Feb 25, 2023 | 12:07 PM
BigBS's Avatar
BigBS
Glad you got it sorted.
Old Jun 6, 2023 | 07:15 PM
daren627's Avatar
daren627
3rd Gear
Default Did you ever get a reply?
It shows moved to C5 tech but I don't find the subject there. I had two fobs I got from Amazon matched to my C5, but after disconnecting the battery I'm stuck at the same place you are or were. I get to FOB training and the hold LCK & UNLCK point but then nothing happens when I hold lock and unlock.
Old Jun 6, 2023 | 11:46 PM
jdmvette's Avatar
jdmvette
Night Owl for life
What year is your C5 and what fobs did you get from Amazon?
Old Jun 6, 2023 | 11:54 PM
daren627's Avatar
daren627
3rd Gear
I've got a 99 and I got the
ACDelco 19299230 GM Original Equipment 4 Button Keyless Entry Remote Key Fob ACDelco 19299230 GM Original Equipment 4 Button Keyless Entry Remote Key Fob
They were like $95 a pop. Had no problem matching them originally. I didn't drive the car for a couple months which isn't unusual, so I've got a battery disconnect switch installed. Car fired right up and has no other issues. Tried to match the transmitters again tonight and can't get past the lock/unlock stage.
Old Aug 13, 2023 | 09:26 PM
BLUE1972's Avatar
BLUE1972
issues with a friends fobs
