C5 z06
Old Jan 1, 2023 | 08:41 PM
davidshaffer5854's Avatar
davidshaffer5854
2nd Gear
Default C5 z06
I fixed my HUD. When I first tested it, it worked. I shut the car off. I secured the HUD. Before I put everything back together I decided to test it all again, when I did, I didn’t have instrument panel lights or HUD. Radio, HVAC, courtesy lights all work. I checked the dimmer and tail lights. Any other suggestions?
Old Jan 1, 2023 | 08:53 PM
The Former's Avatar
The Former
Banned Scam/Spammer
Good luck man. I pulled my dash only to find my car wasn't wired for HUD (too early in the 99 run). I want my 6 hours back! I have zero clue as to what you are facing. Electrical gremlins are tricky. I'm going to bet it's something easy. You've come to the right place though so be patient for an answer.
Old Jan 2, 2023 | 12:33 AM
Moved to C5 Tech.
Old Jan 2, 2023 | 11:08 AM
grinder11's Avatar
grinder11
C5Diag will probably chime in shortly.......
To C5 z06
