C5 Electrical problems(NEED HELP)
Old Jan 9, 2023 | 02:42 PM
Joe_1021's Avatar
Joe_1021
Cruising
Default Please help
I just installed new halo tail lights in my 2003 vette I installed the hyper flash harness and I went to go start it today and my headlights went up and won’t go back down my rear side markers don’t work my halos don’t work my hazards don’t work and I don’t know what to do someone help please.
The halos had connectors on them. I do not know what they are for.
Old Jan 9, 2023 | 09:30 PM
Joe_1021's Avatar
Joe_1021
Cruising
Default C5 Electrical problems(NEED HELP)
I installed my Halo tail lights about 5 days ago they worked perfectly.Yesterday while I was changing my oil I decided to do the Hyperflash harness.Everything worked perfect,today I went to start the car, I unlocked it no lights turned on(I have lights on when unlocked)the only lights that turned on were my reverse lights and corner front lights.Then I turned my headlights on and noticed they wouldn't go back down and my halos didn't work anymore.I took out the hyperflash harness and the same thing was happening.My hazards didn't work but when I pushed my hazard light in and used the turn signals they worked but without the hazards being pushed in they don't work. I ordered a hazard switch.If anyone can tell me what they think it is then I would appreciate it. Thank you
Old Jan 9, 2023 | 10:58 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Have you tried contacting the place you got them from if you bought them new? I personally haven't seen a halo tail light like that one before.
Old Jan 9, 2023 | 11:18 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Your tail light looks to be missing the resistor. The white wires don't need to connect to anything but the red and black should be connecting to a resistor that should have came with them, like this
It looks like your resistors were removed as it should be secured at those 4 hole posts on the back.
Did you buy the tails brand new? If so, from where/who?
Old Jan 9, 2023 | 11:34 PM
jim993's Avatar
jim993
First thing is to make sure that battery side terminals are tight (FSM: 11 foot pounds) and CLEAN.
Next, check battery voltage across the BATTERY terminals, engine not running. 12.6 or more is fully charged; less is trouble.
Next, check battery voltage across battery terminals, engine running. 13 V or more, as high as 14.5 V. Less is trouble.
Next, LOAD test the battery. Most auto parts stores are equipped to do that.
Yes, the hazard switch may be at fault. A way to diagnose is to turn it off and on 20 times and see if symptoms change. If that happens, there are work arounds in the forum besides replacing the switch.
Old Jan 10, 2023 | 12:16 AM
vette4fl's Avatar
vette4fl
Old Jan 10, 2023 | 12:29 AM
Moved this over to the C5 Tech side of the house for some additional assistance.
Old Jan 10, 2023 | 06:28 PM
Joe_1021's Avatar
Joe_1021
Cruising
would the battery being loose do that to my lights and make all my lights not work properly?
Old Jan 10, 2023 | 07:12 PM
mmartinez's Avatar
mmartinez
Always best to check your battery voltage and cable connections, that being said I belive your cars problems are due to the halo lights. Anytime you install led lights you have to have resistors to match the cars original power requirements.
Old Jan 10, 2023 | 07:13 PM
jim993's Avatar
jim993
Loose battery connections can cause a wide variety of symptoms.
Old Jan 11, 2023 | 06:10 PM
Joe_1021's Avatar
Joe_1021
Cruising
I took my battery to AutoZone they said it is a 72%.I’m getting it charged right now.I’m praying it was the problem.I’ll update when I get it back.
Old Jan 11, 2023 | 06:13 PM
jim993's Avatar
jim993
Check this chart.
Old Jan 12, 2023 | 09:41 PM
Joe_1021's Avatar
Joe_1021
Cruising
I was doing research and was wondering if it Could possibly be my headlight switch?
Does that make sense for it to be that?
Old Jan 12, 2023 | 11:23 PM
jim993's Avatar
jim993
If you suspect a battery drain, check this thread and especially post #15.
https://www.corvetteforum.com/forums...t-charger.html
Old Jan 13, 2023 | 12:05 AM
jdmvette's Avatar
jdmvette
Night Owl for life
you must have missed the point made in post #4. if you don't have the missing resistors, try putting your original tail lights back in and see if that fixes everything. if it does, then your problem is the missing resistors.
Old Jan 13, 2023 | 06:30 AM
Joe_1021's Avatar
Joe_1021
Cruising
I tried that already
To C5 Electrical problems(NEED HELP)
