Knock sensor problem
Old Jan 16, 2023 | 12:43 PM
Roger Wing's Avatar
Roger Wing
2nd Gear
Default Knock sensor problem
I have a strange problem with my 2002 Vette. I replaced the knock sensors due to a fault with the front sensor.
I'm still getting the 327 code on the front sensor but only after I drive it and then restart it.
I suspect a wire issue but everything I could see looked great.
Any other ideas?
Thanks, Roger
Old Jan 16, 2023 | 01:18 PM
Smoken1's Avatar
Smoken1
Did you replace the harness also? Someone on the forum just had problem so here is some info that may help you..
https://www.corvetteforum.com/forums...ck-sensor.html
Old Jan 16, 2023 | 03:12 PM
Roger Wing's Avatar
Roger Wing
2nd Gear
Yes I did. I also prepared the moisture barrier that was recommended.
Old Jan 26, 2023 | 11:31 AM
MetalMan2's Avatar
MetalMan2
What brand of sensors did you install? Per the thread @Smoken1 shared, myself and another member had zero luck with AC Delco knock sensors.
Old Jan 26, 2023 | 05:02 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
You might also check the ground wire (pain in the A**) behind the starter on the Eng. block. Had similar headaches and with the help of Mr. Curley
all went fine after that...
mike v
To Knock sensor problem
