Spark Plug Wire (Ohm) Question
Old Jan 18, 2023 | 03:41 PM
Erikf555's Avatar
Erikf555
Default Spark Plug Wire (Ohm) Question
Hello All,
I have an 02 C5 Z06 and am still learning about the Gen III LS6 engine it has.
My question is, when it comes to spark plug wires is looking for a set with 0 Ohms per foot the goal? I’m seeing all the usual high end brands but seeing the Ohm-per-foot rating all over the place.
Can anyone explain if 0 Ohms is ideal or 40? Or whatever?
I appreciate any advice 🤟🏻🏁
Erik(LI/NY)
Old Jan 19, 2023 | 08:48 AM
Erikf555's Avatar
Erikf555
Nobody?
Old Jan 19, 2023 | 09:26 AM
666lisa's Avatar
666lisa
Originally Posted by Erikf555
Hello All,
Erik(LI/NY)
All i can tell u is stock wires are 25mhs per BLUEBLOWNZ06 AKA Bret. Thats what he said yres ago anyway might have changed.
Old Jan 19, 2023 | 09:40 AM
JHrinsin's Avatar
JHrinsin
The LS spark plug wires are very short, so resistance per foot is not a big issue. There is very little energy loss due to resistance. There is NO performance gain from going with an ultra low resistance spark plug wire on a LS engine.
What is a big issue is EMI/RFI, so you need high quality spark plug wires with the correct ferrite core that minimizes any potential static noise interference. There is a whole lot of electrical engineering and physics that I am not going to explain here, which involves particle attenuation, insertion loss in terms of dB and frequency ranges effected.
Let's just cut to the chase. Buy a set of the GM Performance 8mm Red spark plug wires. The old p/n 12495619 had the straight spark boot for the LS1/6. The newer p/n 19351568 (IIRC) has the LS2 spark plug boots with the angled ends that direct the wire upwards.
Old Jan 19, 2023 | 12:25 PM
Erikf555's Avatar
Erikf555
Thanks for the tip. I actually have those wires on now, but plan to buy Holley’s Tall Valve Covers with the neater coil mounting and pre-assumed that I will need a longer set of wires.
Erik
Old Jan 19, 2023 | 12:43 PM
JHrinsin's Avatar
JHrinsin
These?
https://www.holley.com/products/engi.../parts/241-112
Be aware that the stock LS1/LS6 coils will not fit on those valve covers. These valve covers are design for the LS2/LS3/LS7 coils which have a different mounting bolt pattern than the LS1/6 coils. Plus if you switch to the LS2/3/7 coils, you will need a new pair of harnesses for those coils as the primary connectors are different between the LS1/6 and the LS2/3/7 coils. Also once you are done with that you will also have to have your ignition dwell control MAP reflashed to work correctly with those LS2/3/7 coils, since it is different than the dwell control MAP for the LS1/6 coils.
Old Jan 19, 2023 | 12:56 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
40 ohms or 0 ohms over 6 inches or so is insignificant...as mentioned the GM 8mm red wires are fine !!
Old Jan 19, 2023 | 06:51 PM
Erikf555's Avatar
Erikf555
These?
Wow Thanks for that info! Those were the ones I was going to buy too. Do you happen to know of a tall valve cover in that price range that isn’t junk?
Erik
Old Jan 19, 2023 | 09:26 PM
CinciZ06's Avatar
CinciZ06
This is the proform setup. I had the valve covers powdercoated, which made the grooves for the gaskets a little too full and slick to hold the gasket, but after wire brushing those clean they are a great valve cover.
Old Jan 20, 2023 | 01:46 AM
vette4fl's Avatar
vette4fl
Old Jan 20, 2023 | 09:17 AM
Erikf555's Avatar
Erikf555
Thanks, looks really good 👍🏻
Old Jan 20, 2023 | 09:23 AM
JHrinsin's Avatar
JHrinsin
One other option if you need a taller valve cover for clearance, is a set of billet spacers that fit between the head and the valve cover.
Old Jan 20, 2023 | 09:26 AM
JHrinsin's Avatar
JHrinsin
Also if you relocate the coils higher or more inward toward the fuel rails, a set of spark plug wires for a LS truck engine are about 2" longer than those for the car applications.
Old Jan 21, 2023 | 12:22 AM
Lowend's Avatar
Lowend
To answer the question: 50 - 300 ohms/foot is considered good.
And I agree with the length of LS wires it's not important. I've found no reason beyond aesthetics to run anything but AC Delco wires
Old Jan 21, 2023 | 03:09 AM
vette4fl's Avatar
vette4fl
Clean setup. 👍
Old Jun 5, 2023 | 04:23 PM
stockC5's Avatar
stockC5
The red wires I just pulled from my 02 Vette Ohm at between 375 ohm and 380 ohm. The wires and plugs have 40k miles on them.. The AC Delco 41-110 plugs still looked good and all gapped at .040.
Old Jun 5, 2023 | 06:12 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
100% DIT DOT CORRECT! Best bang for the buck wires going!! The fit correctly, Stay connected, are high quality and NOT over priced!
Bill C
Old Jun 5, 2023 | 06:15 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If memory serves me correctly, the service manual says 250 -750 OHMS end to end. Most of the C5 wires thatI have measures are pretty close to 330. ohms.
Old Jun 10, 2023 | 09:40 PM
stockC5's Avatar
stockC5
UPDATE!!!! Wow! Just install new GMPP plug wires. They OHM out at 25 ohm! The Vette now runs like a dream. Big difference from 375 ohm to 25 0hm! Also installed 41-962 iridium plugs. This is a one owner car and believe me, I can really see the difference in performance and throttle response.
To Spark Plug Wire (Ohm) Question
