auto trans concern
Old Feb 8, 2023 | 08:25 PM
alcoed's Avatar
alcoed
Default auto trans concern
I have a strange auto trans concern and wondering if anyone has/had a similar situation. After driving at freeway speeds for about 30 or 45 minutes with a steady 55/65 mph the torque convertor releases from lock up. If you accelerate you can feel the clutch engage. If you just do in town driving there is no problem. All gears shift positive and you feel the convertor clutch lock up at the correct speed. I did pull the pan for inspection and fluid change. Pan was clean and fluid clear red.
Old Feb 8, 2023 | 08:43 PM
Supercharged111's Avatar
Supercharged111
A misfire can cause this. Got any codes? If not, log for misfires counts.
Old Feb 8, 2023 | 09:29 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Hi Ed !!…if your concern is happening more often bring it back down here and we will see what’s going on !!…I can’t diagnose it if it’s not happening…if you want to swing by this weekend let me know.
Old Feb 8, 2023 | 09:40 PM
C5 Diag's Avatar
C5 Diag
No misfire codes stored when I did a code scan.
Old Feb 8, 2023 | 11:29 PM
jim993's Avatar
jim993
The A4 is not full of fluid unless-
The car is raised or on jack stands, engine running, transmission in park and transmission temperature 122 F -- and fluid drips out the open fill/ drain plug hole. The plug MUST be put back in before shutting down the engine.
Old Feb 9, 2023 | 06:48 AM
alcoed's Avatar
alcoed
No codes, lifted car on quick jack, checked fluid hot while running found it to be full. At a point that I might sell at a discounted rate!
Old Feb 9, 2023 | 06:51 AM
alcoed's Avatar
alcoed
Default stubborn fix
Thank you, I will give you a call.
To auto trans concern
