Automatic Shifter Problem
Old Mar 14, 2023 | 06:58 PM
BobKorinekC01's Avatar
BobKorinekC01
3rd Gear
Default Automatic Shifter Problem
The shifter works fine when cold, but when hot it will not go into reverse and feels disconnected. I have had the cable replaced. The car has 51,000 miles on it and has been well taken care of. With some effort back and forth it can finally be coaxed into reverse. The transmission itself performs fine. Could the shifter itself be at fault?
Old Mar 14, 2023 | 07:28 PM
yellow2007's Avatar
yellow2007
If it's like my C6 there are two cheap a$$ bushings. One on the tranny and one on the shifter assy. New cable not withstanding that could be the issue.
Old Mar 14, 2023 | 10:00 PM
SilverC54me's Avatar
SilverC54me
There is a cable adjustment on the trans end of the cable. Possibility that the lock for the adjustment is not set. Have had this happen on a friend's car. It was a bit tough to get the lock to set.
Gary
Old Mar 15, 2023 | 12:50 AM
Moved to C5 Tech.
Old Mar 15, 2023 | 07:18 PM
BobKorinekC01
3rd Gear
Thanks for the tip, that's exactly what was wrong, the cable was floating in the rear anchor bracket. Easy fix.
Old Mar 15, 2023 | 07:22 PM
BobKorinekC01
3rd Gear
Thanks SilverC54me, that's exactly what was wrong. The cable was floating in the rear anchor bracket. Easy fix, thanks again.
To Automatic Shifter Problem
