P1120, P1220 - TP Sensor 1 & 2 Circuit Problem
- APP (accelerator pedal position) sensor
- TPS (throttle position sensor)
- TAC (throttle actuator control) module
- Faulty wiring/connection
From my understanding, throttle position sensors 1 & 2 are both integrated into the construction of the throttle body. If this is the problem, I need to replace the ls2 throttle body for $500+ or perform "electrical surgery" on the ls2 throttle body. If the APP sensor is the problem, then I need to replace the pedal assembly for a fraction of the price of a ls2 throttle body (hopefully this is the problem). If the TAC module is the problem, then I need to replace the TAC. I'm not too sure which of these 3 items is problematic (or faulty wiring/connections).
I have attached a HPL file from my VCM scanner that shows my throttle position percentage and accelerator pedal position percentage. This test was with the ignition off and accessories on. When the accelerator pedal is fully depressed, my throttle position is at 100% and my accelerator pedal position is at 112%. How can my APP be above 100%? Is that normal? In the test file, I slowly depress the pedal, and if you pay attention to the throttle position percentage, as it reaches 20-30%, the throttle seems to not move linearly with the accelerator pedal position.
My car is tuned with an LSA blower and I'm not sure if my tuner changed parameters with the pedal position (see attached HPT file) or if changing APP parameters are even possible in HPT.
From this information, what is the problem? The TPS? The APP sensor? Or maybe the TAC?
How should I go about diagnosing the problem?
@Bill Curlee @Speedy007 @whatyacallit @C5 Diag I hope you're all still active around these forums because you all gave some insightful information regarding this issue I had nearly 4 years ago (this is the same problem from a pervious thread 4 years ago but I narrowed the problem down).
Best,
bbuddine
1. Throttle position sensor [Voltage]
2. Throttle position sensor 2 [Voltage]
Try and clear the codes. Do the same test you did and lets see what the PCM is seeing.
Also on a side note it in VCM editor it looks like you're still running a 1 bar MAP sensor. How many LBS of boost are you running?
Also referring to your question about your APP. In VCM editor if you go under Engine/Airflow/Electronic throttle/Desired throttle area you will see why your throttle position is different than your pedal position. Examples: At 25% pedal position your map shows only 3.79% at 50% pedal position it's at only 15.06% at 75% it's at 46.78% Not until you reach 94% pedal position wil you get 100% throttle opening. All this to say that there is nothing wrong with your APP so cross that off the list.
Don't mess with these settings unless you REALLY know what you're doing!
[ECM] 33000 - Desired Pedal Area - Normal: Desired throttle area based on pedal position and barometric pressure (pedal to throttle map). WARNING!!! Modify this table at OWN RISK. Incompatibility of this calibration with the vehicle TAC module calibration may render PCM permanently inoperable.
Good luck
Good luck
See attached HPL file. There was not an existing channel for a throttle position sensor 2 that I could find in the drop down menu (see below image) but there was a option to add throttle position sensor 2 in the chart vs time graph. Throttle position sensor 1 was reading zero volts across the span of 0%-100% of the accelerator pedal and looking back at the test file, it looks like the file didn't save the chart vs time graph for TPS voltage because it was at zero volts? Maybe I I didn't log something correctly? After I connected the vehicle to the scanner , I relogged the VCM suite to refresh any parameters that may not have been active. I am running approximately 11 lbs of boost. I have a 3 bar map sensor, but I just haven't tuned the car to a 3 bar open loop because I don't know how to do that and I want to stay away from bricking my ECM.
One piece of info for you.....You wrote (Throttle position sensor 1 was reading zero volts across the span of 0%-100% of the accelerator pedal and looking back at the test file, it looks like the file didn't save the chart vs time graph for TPS voltage because it was at zero volts? Maybe I I didn't log something correctly?)
When I was testing I noticed that mine showed 0 volts too. My car runs fine so It's probably a problem with HP Tuners.
I went ahead and purchased a LS2 throttle body. I'm assuming that this is the issue. If it's not the issue, I can return it and I will report back. Thanks for the advice though.
Thanks for testing on your own to validate the problem with the VCM scanner.
If the LS2 throttle body is problematic, what other throttle body should I go with to fix the issue?
Best,
bbuddine
This kit gives you an option to use an available sensor. Seems to just be a crossover harness with a dorman sensor.
