How much does the C5 weigh??
Old Jan 15, 2003 | 08:55 AM
jschell's Avatar
jschell
Default How much does the C5 weigh??
I looked on the inside of my door and it says 3,700 lbs!!! :eek: Is this accurate???
Old Jan 15, 2003 | 09:06 AM
Crushinator's Avatar
Crushinator
Default Re: How much does the C5 weigh?? (jschell)
1997 coupe 3,227lbs
1998 coupe 3,245lbs
1999 coupe 3,245lbs
2000 coupe 3,246lbs
That's all the higher my Black Book goes.
Old Jan 15, 2003 | 09:07 AM
indyblue98's Avatar
indyblue98
I think what You are reading is the max capacityof the car including passangers and luggage. The car itself is more like 3250. :blueangel:
Old Jan 15, 2003 | 09:24 AM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
I saw the same thing last weekend. I about fell over. :smash:
Old Jan 15, 2003 | 09:25 AM
Jochen's Avatar
Jochen
According to the homepage of Chevrolet Europe the (empty) weight of the C5 varies from: 1538 to 1548 Kg. This calculates to 3391 lbs to 3413 lbs, depending of the options you have on your car.
Jochen
Old Jan 15, 2003 | 09:35 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Re: How much does the C5 weigh?? (Jochen)
I agree with Jochen :iagree: The more options the more weight!
Old Jan 15, 2003 | 02:14 PM
BLU-BY-U's Avatar
BLU-BY-U
my Z06 is 3050 with no driver and 1/8 tank gas, as measured on the scale at NHRA approved Houston Raceway Park.
No wonder these things haul a-s-s :steering:
Old Jan 15, 2003 | 02:17 PM
Untouchable00's Avatar
Untouchable00
Mine is 3214lbs.
Old Jan 15, 2003 | 03:48 PM
YOULLUZ's Avatar
YOULLUZ
Default Re: How much does the C5 weigh?? (BLU-BY-U)
My Hardtop is 3080# w/ 1/4 tank in it. Certified scale of course.. :hurray:
Gotta luv them hardtops !!
Old Jan 15, 2003 | 04:03 PM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: How much does the C5 weigh?? (YOULLUZ)
My 97 Coupe weighed in on the old Watkins Glen scale at 3165 with about 3/4 of a tank.
Bill
Old Jan 15, 2003 | 11:35 PM
KorbenDallas's Avatar
KorbenDallas
You don't have a Trans-Am do you? :lol:
Old Jan 16, 2003 | 09:00 AM
jschell's Avatar
jschell
Default Re: How much does the C5 weigh?? (FroDaddy)
Maybe they coated my car with an added layer of iron protectant!! :lol:
glad to hear she isn't that heavy, i was gonna put her on a diet!
Old Jan 16, 2003 | 09:39 AM
Mark S.'s Avatar
Mark S.
Default Re: How much does the C5 weigh?? (Untouchable00)
Mine says 3,6__lbs something...I remember looking at it the other day when I had the door open.
Old Jan 16, 2003 | 10:26 AM
rev4679's Avatar
rev4679
Default Re: How much does the C5 weigh?? (Mark S.)
mine weighed in at 3175 lbs, can't remember how much gas was in it.
Old Jan 16, 2003 | 12:02 PM
BigBlue's Avatar
BigBlue
Default Re: How much does the C5 weigh?? (rev4679)
Here's something I've been thinking about. Wouldn't a convertible way less than the hatchbacks (the ones with the glass hatch in the back) since there are no electrics in the roof and it is just a frame with a piece of cloth on it?
Old Jan 16, 2003 | 01:20 PM
JBS11's Avatar
JBS11
Default Re: How much does the C5 weigh?? (BigBlue)
IF you were referring to a C-4, then you would be correct about a noticable weight difference between the Coupe and Convertible. But... the Vert would weight MORE than the Coupe.
Reason being: The C4 was designed as a Coupe. In 1985, GM decided to add a Convertible C-4 to the stable. The C-4 was not very strong once the top was off the car... so they were forced to design an "X" bar to go under the car and an "I" bar in the from of the car to help make the car stiffer. This additional material added some weight to the car and vastly off-set any savings. The Verts weighed ~100-250lbs more depending upon options.
Fast forward to the design team for the C-5. THey learned from past mistakes and designed the C-5 off of a convertible platform. With that in mind, they aimed to make the car as stiff as possible without over-weighting the Convertible. The Coupe was then designed simply by adding a top... (I am sure more went into it...) Total weight difference between equally optioned Coupe & Convertible is insignificant. (~10lbs.)
Old Jan 16, 2003 | 02:36 PM
te51cle's Avatar
te51cle
My 02 Coupe weighs exactly 1500kg with 1/4 tank of petrol and me in it and 1440kg when I stepped out of it and went to read the scales with the operator. That's about right as I weigh less than 11 stones.
In lbs those weights are approximately 3320, 3190 and 133 !
To How much does the C5 weigh??
Old Jan 16, 2003 | 02:55 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
I put mine on a scale at the Drag strip and it came out to be exactly 3,200 lbs
vetterdstr :cheers:
Old Jan 16, 2003 | 03:34 PM
MySea6's Avatar
MySea6
Default Re: How much does the C5 weigh?? (vetterdstr)
vetterdstr :cheers:
That is exactly what my coupe weighs with ~1/4 tank of gas.
What bothered me the most from the "sticker" was the capcity of 399 lbs. Guess either my wife our I need to go on a diet. Rethink.......my wife only weighs___ Dayum, ok I'll start tomorrow. :lol: :D :lol:
Old Jan 16, 2003 | 07:54 PM
J-Rod's Avatar
J-Rod
Default Re: How much does the C5 weigh?? (MySea5)
Mine is 3012 to 3021lbs at HRP depending on fuel load without me in the car...
