Window Valet HELP
Old Jan 15, 2003 | 11:40 PM
1Bad2000C5's Avatar
1Bad2000C5
Default Window Valet HELP
I installed it followed instructions go to program windows enter pin code and the windows roll all the way down but not back up like it says theys hould and they remote doesnt work to put them back up.help me yall
thanks
dave
Old Jan 15, 2003 | 11:46 PM
dads01dream's Avatar
dads01dream
Default Re: Window Valet HELP (1Bad2000C5)
It was about a yr. ago that I installed mine. I vaguely remember there be a few little glitches like this. Just try re-programming it, follow the directions carefully and it should workout fine. Mine used to bounce back down when at the top, but after a careful setup it worked great.
Be patient! It's worth what little effort it takes. I ENJOY mine each & every time I drive my Vette.
:seeya
Old Jan 15, 2003 | 11:56 PM
Killrwheels's Avatar
Killrwheels
Default Re: Window Valet HELP (dads01dream)
werent their additional options, ie. menus, that needed to be chosen on the DIC. Start again from scratch, and remember three times in quick succession.
Old Jan 16, 2003 | 12:00 AM
chocoholic's Avatar
chocoholic
At this point, the best thing to do is call Michael Fuller at Top Down Tech. He's a super chap and he'll fix you up in no time flat.
Old Jan 16, 2003 | 02:30 AM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
Default Re: Window Valet HELP (chocoholic)
I agree Michael is great :iagree:
Old Jan 16, 2003 | 12:12 PM
ddawson's Avatar
ddawson
Default Re: Window Valet HELP (Wicked C5)
Try the program again just to make sure you’re in the right programming section.
If you still have problems get a hold of Michael. He will email you back pretty quick.
Old Jan 17, 2003 | 12:01 PM
Avanti's Avatar
Avanti
Default Re: Window Valet HELP (ddawson)
Instructions must be followed exactly! It's easy to make a little bobble the first time or two. Patience, Grasshopper. You cannot hurt anything. Try again. :yesnod:
Old Jan 17, 2003 | 12:08 PM
HOTSOSS's Avatar
HOTSOSS
Default Re: Window Valet HELP (Avanti)
And if you need to take your car in for service where they might plug in diagnostics, just remove the little fellow and then re-install it when you get the car back. No re-program is necessary.
Old Jan 18, 2003 | 05:15 AM
EHS's Avatar
EHS
:iagree:
Follow the instructions exactly. Don't skip a step or skip around.
Depending on when you got the WV, you may find easier instructions on the web site.
Give it a try. Do it exactly. It does work.
To Window Valet HELP
