Need Help Finding Problem
Old Apr 30, 2023 | 12:33 AM
usernamebrennan's Avatar
usernamebrennan
2nd Gear
Default Need Help Finding Problem
Have recently bought a 1999 C5 Corvette was driving fine and all of a sudden it's started to have a kinda ratteling sound near the belt, wondering what needs fixing. Thought I should get other peoples opinions and see if someone else has had a similar issue. Have already replaced the tensioner.
https://drive.google.com/file/d/1b5h...ew?usp=sharing
(Link to video above)
Old Apr 30, 2023 | 01:15 AM
brentsz06's Avatar
brentsz06
i cant see the video, but whats your crank pulley doing?
Old Apr 30, 2023 | 01:30 AM
usernamebrennan
2nd Gear
Not really sure it looks like there might be a little wobble but it's not obvious.
Able you able to see the video through this link?
https://streamable.com/wrvhd8
Old Apr 30, 2023 | 11:14 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Sounds like some bearings are starting to go. I'd take the belt off and "hand spin" your tensioner, water pump, power steering pump, alternator and listen for the noise. Pretty easy to isolate at that point.
My bet is on the tensioner.
Old Apr 30, 2023 | 04:56 PM
rrwirsi's Avatar
rrwirsi
I see you are in New Zealand. Is there any Corvette repair shops in the 'down under' that can sort out the noise. Otherwise, suggest taking it to a trusted mechanic and let them have a look.
Old Apr 30, 2023 | 07:30 PM
killain's Avatar
killain
Oldtimer
I think your belt tensioner is starting to fail, but like Bill said above, easy enough to remove the belt for a few minutes to see if the noise goes away !
Old Apr 30, 2023 | 11:48 PM
vette4fl's Avatar
vette4fl
Not just the tensioners, but the pulleys themselves. If even one is bad, change them both.
Old May 1, 2023 | 12:54 AM
Moved to C5 Tech.
Old May 2, 2023 | 01:21 PM
Gskeeters's Avatar
Gskeeters
had a very similar noise and both idler pulleys and tensioner replacement did the trick ( belts too while there) pulleys were more evident when pulled. They would rattle when shook.
To Need Help Finding Problem
