Another limp C5
Old May 9, 2023 | 08:09 PM
njoy's Avatar
njoy
Default Another limp C5
Mechanic has had my 2003 Anni coupe for 8 weeks and thousands of $$$, but still unable to get her out of Reduced Engine Power mode. The throttle body and pedal position sensors have been replaced. Codes thrown yesterday (when I went to pick her up): P1125 - TP/APP Sensor Circuit Problem and P1286 - APP Sensor 3 Circuit Performance. Any suggestions from the Forum? I, too, may have reached the end of my budget and may consider putting her up for sale. 135K miles, manual, 2 tops. I'd prefer to get her back on the road, though.
Old May 10, 2023 | 01:41 AM
Alley Oop's Avatar
Alley Oop
Got this from an old Johnny Hardcore post
had reduced power occur due to a frayed wire in the passenger side door loom causing a short.
Maybe check the driver's door??
Old May 10, 2023 | 04:47 AM
njoy's Avatar
njoy
Wow - thanks! It actually has had issues with the door.
Old May 10, 2023 | 10:50 AM
whatyacallit's Avatar
whatyacallit
It's not a door wiring problem throwing those codes.
Might want to check this out even thought he had a different code.
The APP communicates with the TAC (Throttle Actuator Control) module before a signal is sent to the throttle body. It's mounted to the PCM and is located behind the passenger side wheel well. Check the wiring there.
TAC Module problems - CorvetteForum - Chevrolet Corvette Forum Discussion
Old May 10, 2023 | 06:23 PM
njoy's Avatar
njoy
Thank you! I'll pass this information on to the mechanic.
Old May 10, 2023 | 07:56 PM
Johnny Hardcore's Avatar
Johnny Hardcore
This is a long read with a TON of information pertaining to electrical and ground issues that cause "limp mode" to occur. As mentioned above my issue was caused by frayed wires in the passenger door loom. My car threw 15 or more codes when this occured. Which codes they were I don't recall. My car acted like it was possessed when I had the issue.
Courtesy of Bill Curlee...this thread provides many reccomended steps to take to trouble shoot "limp mode". Including TAC replacement, cleaning grounds, wire looms in doors etc.. Good luck!
https://www.corvetteforum.com/forums...tion-long.html
Old May 10, 2023 | 09:10 PM
v8srfun's Avatar
v8srfun
I would also suggest a new mechanic if he can’t test parts he is replacing to know if they are really bad he is just wasting your money. You will spend less in the long run with a qualified mechanic that knows his way around proper diagnostics.
Old May 11, 2023 | 07:26 PM
njoy's Avatar
njoy
Yes! Thank you! I sent this to my mechanic. I think these are the next steps to take.
Old May 11, 2023 | 07:32 PM
njoy's Avatar
njoy
This is a multi-generation Corvette mechanic who has taken care of my car for the last 15 years. When he said: "I just don't know what else to do" is when I began my Forum inquiry. I wish I had consulted you guys weeks and $$$ sooner.
Old May 11, 2023 | 09:32 PM
v8srfun's Avatar
v8srfun
but he is replacing parts not knowing if they are bad. If he is not able to run basic diagnostics and resistance checks on parts he is not a mechanic he is a qualified parts changer. Or in other words his reputation is better than his results. It is inexcusable to throw parts at a car to the point that the customer is considering selling the car because the guy can’t diagnose.
Old May 13, 2023 | 10:49 AM
grinder11's Avatar
grinder11
^^^^^^Truer words have never been spoken^^^^^^
To Another limp C5
