New tire question
Old Jan 16, 2003 | 11:41 PM
OhNiner's Avatar
OhNiner
Default New tire question
I am at the point where I almost need new tires. Here is my concerns. I can keep run-flats or buy non run-flats. If I buy run-flats and get a flat on the road I can drive about 50 miles, then I guess the tire is ruined. If I need to replace that tire I will need a service center that can handle run-flats. With non run-flats any service center can mount a new tire.
This has me leaning toward non run-flats, what are your thoughts?
Old Jan 17, 2003 | 06:30 PM
tom p's Avatar
tom p
Default Re: New tire question (Gardiner)
i felt the same way as you do. Even if you get 50 miles to a service station i am 99% sure they are not gonna have emt's in stock. so you end up buying one non runflat to get you home or gettin it pluged (if it is not ruined). I ditched my run-craps last fall and bought bfg kd's ,bigger tires= more grip and much much better ride and feel. It's kinda a catch22 so you might as well get the better ride with the good rubber. Just remember if you keep the sensors and try leak-goo when you get a flat you will kill the sensor forever! You will also kill the sensor if ya get a blowout at high speed. Its a sacrifice (and chance) i don't mind takin. LUV THE G-FORCE'S they ripppp :chevy
Old Jan 17, 2003 | 07:07 PM
catbert's Avatar
catbert
Default Re: New tire question (tom p)
I don't feel like I'm giving up much with the new generation run-flats. If my choice was the old Goodyears, I'd switch in a New York minute.l
Old Jan 18, 2003 | 04:12 PM
tom p's Avatar
tom p
Default Re: New tire question (catbert)
what type of emt are you using?
Old Jan 18, 2003 | 04:57 PM
catbert's Avatar
catbert
Michelin Pilot Sport ZPs
[Modified by catbert, 3:02 PM 1/18/2003]
Old Jan 20, 2003 | 01:45 PM
Darrell G's Avatar
Darrell G
Is there such a thing as a compact spare that will fit the vette? Is there a big reason why you shouldn't do this?
To New tire question
